175 Allis lift cylinder rebuild |
kenney58
Topic: 175 Allis lift cylinder rebuildPosted: 17 Jun 2024 at 11:53am |
I had read once on replacing cylinder seals on the 3 point lift. Am unable to remove pin in the front of cylinder in front of axle housing. And advice?
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7644 |
Posted: 17 Jun 2024 at 3:10pm |
Going to need some heat and penetrating oil. Have done it several times. Removing the floor pan and traction booster linkage helps a lot.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 729 |
Posted: 17 Jun 2024 at 3:18pm |
I know D17s4 cylinders and 175 cylinders are probably different but on my D17 i plan to just take the pin out of the rod end screw the cap out pull the rod out and leave the tube on the tractor. Am i think wrong for some reason
1984 80780
