12 Volt Generator Arcing
KD8NGV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Topic: 12 Volt Generator Arcing
    Posted: 28 May 2024 at 11:04am
Working on a no-charge issue on a D10.  12 Volt Positive Ground.  I had the generator taken to a machine shop to test and was told it was charging correctly and pointed the blame to the Voltage Regulator (VR).  I opened up the VR and found the points were needing a clean and did so.  I made no changes to the VR.  I can go into the details of my testing, if you would like.
I placed the VR and Generator back on the tractor, polarized it, and started the tractor.  No Charge.  When I grounded the Field connection, no charge.  Thinking the cutout portion of the VR could be bad, I closed the VR cutout circuit, it held itself shut and the generator started charging.  However, one of the brushes was arcing quite a bit.  I shut the tractor off, the cutoff circuit opened as it should.  I started the tractor again, no charge.  I closed the cutout relay in the VR and charging occurred.  I saw the arcing on the brush and performed a short experiment.  I throttled up the tractor and took it back down.  The faster the rotation of the generator, the more arcing the brush had.  The lower, the less.  Made sense to me that it would do it.  I shut the tractor off, the cutoff opened as it should.
My question is this:  What would cause arcing (white light) from the brush of the generator?  I assume that any arcing in an electrical circuit is not good.  Is my generator not as good as the shop thought it was?   Anything I can do to "fix" or remedy the arcing?
Thanks,
Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 11:20am
have you thought of using a 10SI alternator instead of generator .
Arcing would be the brushes bouncing on armature , either rough or worn brushes .
https://chevy.oldcarmanualproject.com/electrical/49dr324/index.htm
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 1:01pm
You might try wiring a capacitor (condenser) to the armature post and it can reduce the sparking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 1:07pm
I would like to keep the tractor original with the generator if at all possible.  I appreciate the link to the information.  I will read that over.  I assume it has information on how to remedy bouncing brushes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 1:08pm
Would you use a standard condenser you would use in a distributor?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 2:09pm
Link has a lot of info on older systems used by AC Delco .
Info is set under different headings on site .
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 2:17pm
I know what I will be reading up tonight.  I'll report back my findings.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 2:52pm
Take it back to the shop that worked on it to begin with.  They were the ones who last worked on it.  Buy a new voltage regulator from them as well . it has to be mated to the generator.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 3:46pm
An arcing brush is not good. Either the armature needs to be turned or the spring that holds the brush against the armature is broken or weak. Either way the shop needs to open it up and figure out whats causing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 4:48pm
AND... get a new regulator that is sized to the generator,
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 8:19pm
Update.  Tonight I took off the generator to inspect the spring and brush.  The spring had a decent amount of snap to it.  I noticed on the armature that there was a section of bright copper that seemed to be a bit shallower than the rest of the surface.  It was certainly brighter than the rest of the armature.  I then inspected the offending brush and it had what looked like little balls or build up on the edge.  Not enough that I thought it was pushing up the brush, but of note.  If you would like, I can try to get some pictures.
I remembered that I had a spare generator recently rebuilt in my other shop, so I grabbed it, installed it, polarized it, and installed it.  I ran the tractor without the Field or Armature posts hooked up as I could not remember if it was setup for 6 or 12 volt and the tag is not on the generator.  I attached my multimeter from the armature post and the other lead to the ground.  I then grounded the Field and saw a 30+ volt charge.  I shut down the tractor, knowing that it should be good for 12 volt and hooked it up to the charging system.  Upon starting the tractor up, the voltage regulator worked as it should and the system starting charging.  I was getting high 14 volts at the battery and the armature terminal both.  Adding a load to the system by turning on the lights, the regulator kept the system charging.  The Ammeter only has markings for 0, 30, and 60, so my guess was that the generator was charging my battery around 10 amps.  When the tractor idle speed was lowered rather low I saw the cutout release and open the circuit. And when I added throttle, the cutout closed the circuit and charging commenced.  Since the tractor has been running without a charge on the battery, I imagine that it will take some time if I was running the tractor to fully bring it up to charge and cause the VR to not have to send 10 amps to the battery.
Now that I feel like I have proved that the generator is the problem, off to the shop she goes.  The voltage regulator seems to be working.  (Now to find an OEM 30-amp gauge instead of the 60)
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 8:22pm
I will be taking it back to the shop.  I called him today to let him know it was arcing bad.  I'll have him open it up and do a full inspection.  While he ran it on the tester and saw good charge, I wonder if he did not see the arcing while it was on the tester.  This shop has done me right on many projects, so I have grace in this case for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2024 at 8:25pm
Excuse my ignorance, how does one size a regulator to a generator?  I have assumed (We all know what that means) that if I had a factory generator, then the prescribed regulator would be what I need.  I suppose I have not seen a spec sheet when looking at tractor regulators.  Other than the voltages (6 or 12) I assume that the sizing would also be for amperage?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2024 at 7:26am
I'm coming into this a little on the late side, but the arching in my opinion sounds like a bad comm plate. When it comes to sizing up a VR for a Generator or Alternator, the way I've been doing it for 53 years in my rebuilding business is if the tag is still on the unit, you look up the information on the unit's output. Min. and Max. Once you know what the perimeters are of the unit, that's how you mate a VR to the unit. If the tag is missing, one needs to run the unit on an 881 machine or equiv. and do some load tests on that unit to see where the charging perimeters are and then mate a VR to it. The Gennie and the VR need to work as a team. To many times people make the mistake of purchasing a "universal" 12V VR, and the unit is not compatible with the Generator or Alternator its being used with.  HTH
Steve@B&B
bb-customcircuits.com
Edited by Steve in NJ - 29 May 2024 at 7:28am
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2024 at 8:17am
Critical factors:
Voltage rating (6, 12, 24, etc.)
Field Current
Generator Output Current
Output current of most alternators is irrelevant because alternator current is self-limiting by design so the regulator only controls the voltage level.
Most generators (Dynamos) require some form of current regulation as they will attempt to melt down if the amperage is not controlled. The simple 'Third Brush' type generators used on Model B/C  have the current output limited by adjusting the third brush so they only use a cutout relay to prevent discharging the battery when the generator output is too low.
Post Options Post Options   Thanks (1) Thanks(1)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2024 at 1:34pm
Update 2:  Took it back into the shop and they are going to tear it down and inspect.  I will report back on the findings.
