Finish Mower Gear Box Oil Change? |
Dave H
Orange Level Joined: 11 Sep 2009 Location: Central IL Points: 3491 |
Posted: 03 May 2024 at 8:58am |
The gear oil in the 6 foot Woods finish mower resembles something that comes out of the rear of the local Canada Geese. I want to change it. Only thought for now is to pull the fill plug and hoist the mower up on it's side with the front loader. Any suggestions on a better way?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80171 |
i have used a Rose Gun.. basically looks like a grease gun without a grease tube.. Stick the hose into the fill port and pull back on the rod and it SUCKS the oil out.. Works good on oil or gear lube.. Not so good if it is THICK or grease... If your seals dont leak and it still has gear lube ( instead of grease) this may work... If the fill is on the SIDE, then i have used a copper tube bent into a sweeping 90 degree to get into the hole.
Dave H
Update - Fill lug is on the side and vent plug is on the top. Good tip Steve. Now I an going to price one of those sucker guns.
Auto Zone, WAl Mart, Farm Store...
Dave H
Thanks Steve - got one ordered from Amazon
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41474 |
Used what was called Steam Cylinder Oil in all the industrial gearboxes I use to service or rebuild - Mobile 600 W steam cylinder oil
