Wanted D-17 Battery Parts |
Michael (WI) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Larrabee, WI Points: 811 |
![]() ![]() ![]() ![]() ![]() Posted: 03 May 2024 at 3:13pm |
I am in search of a good used battery tray, battery hold down clamp and J hooks for a D-17 with a gas engine. I am located in northeast Wisconsin so if it is not located locally it would need to be shipped.
BigGuy1000 ![]() Bronze Level ![]() Joined: 06 Dec 2013 Location: NWIL Points: 108 |
You can still buy the NOCO brand battery holddown and J hooks (for AC 170gas if same) at Farm and Fleet, Tractor supply, etc. NOCO no longer has the larger size holddown and J hooks, for a larger battery on other tractors.
ValleyFarm ![]() Bronze Level ![]() Joined: 07 May 2022 Location: Greenleaf, Wi Points: 18 |
Hi Mike. Check with Wisconsin tractor parts in Black Creek. They may be able to find you a used one. Or if your good with a welder. You could have a fab shop make you a tray and cut the old one off and weld the new one one. I've also seen them new running around on different websites. Hope this helps.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4445 |
There are different trays for different series. I know the Series 4 is different than Series 1 or 2. Not sure about Series 3.
The tray for a Series 4 are hard to find.
Travis(NE) ![]() Silver Level ![]() Joined: 24 Sep 2009 Location: Seward NE Points: 294 |
Reproduction battery trays are or were available. I believe A&W Tractor or DJ's Tractor parts offers them. There are two styles that I am aware of, the early style is for the oil bath air cleaner used on the series 1 and 2 and the second is for the dry filter used on the series 3 and 4.
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 970 |
Have reproduction trays available for early D17.
According to what I have seen, Series 1, 2 and 3 took the same tray. Series 4 were different.
