7030 transmission fluid transferring |
Orange & silver farm ![]() Bronze Level ![]() Joined: 29 Jul 2021 Location: Ohio Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Apr 2024 at 4:39am |
7030 is transferring trans oil to rear end. I know this has been discussed before. I pulled filters and screens underneath left and right they were pretty clean. Will get new agco. Figured I need to change the seal to stop the bypassing of oil. Anyone have part number of the seal and is there anything else I'll need? (Gaskets) How big of a job is it to change? Am I going about it right so far? Any suggestions greatly appreciated thanks and first time poster
Ron(AB) ![]() Orange Level ![]() ![]() Joined: 27 Dec 2009 Location: Alberta Points: 962 |
Welcome to the forum.
Yes it is probably best to do as many seals as you can when you are in there. |
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22015 |
70265398 is the seal causing the trouble. Be sure to wrap one layer of electrical tape on the shaft splines to prevent cutting the seal when installing. Other parts needed: two- 70269665 Orings.....one- 70261282 gasket.......one-70924921 oring. Reuse all the seals you can as many are obselete i am told.
Thank you that's what I was answer I was looking for. Wanted to get seals before I started repair
