Bypass line on pressure switch,,,,,,?,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: Bypass line on pressure switch,,,,,,?,
    Posted: 23 Dec 2023 at 10:05pm
  i had ordered a Square D pressure switch from Amazon that had a delivery date of Dec 29and then received a notice that delivery date would not be met due to "unforeseen Supply Issues" ,,,,? Sounding some familiar,,,,?
SO,,really needing the compresor,,,, I opted to accept a no name (china?) pressure switch that they say is their best seller.
 Got new pressure switch all lashed up and was kinda puzzled as the steel nut and ferral that goes on the 1/4"  copper tubing line on the By-Pass line that is on btm side of the pressure switch itself  did not fit well and was a tad smaller than the regular 1/4" copper tubing line size,,,WTH????
 When compressor reached the 120# shut-off pressure ,,the pressure switch "SPIT" and shut the motor OFF and the metal nut and ferrel connection started to UNLOAD to atmosphere continously until tank pressure got back down to 90# and the by-pass line again "SPIT" and restarted motor  and it shut off at 120# like it was susspossed to,,,,,
 The other pressure switch did not continue to unload to atmosphere,,,SO is there maybe something wrong with this pressure switch,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2023 at 10:09pm
the pump pushes thru the line, thru a CHECK VALVE and into the tank... The small line from the switch SWITCH is on the line between the check valve and the pump... When the LITTLE LINE SPITS, it relieves the pressure between the CHECK VALVE and the PUMP...
EDIT... i just looked at my compressor.. The Pressure switch screws to the TANK and measures the pressure.. The little line goes up to the pump discharge line.... Apparently your NEW VALVE is BAD... It should relieve the little line ONLY, not the tank..
Edited by steve(ill) - 23 Dec 2023 at 10:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2023 at 10:45pm
i think a lot of them small regulators have a DIAPHRAM on the inlet into the switch.. It will FLEX and read the pressures in the tank, but will not allow the TANK air to get up into the switch.. Your diaphram is broken / leaking.
Take the switch back off and look up inside the threaded pipe nipple to see the diaphram.
Edited by steve(ill) - 23 Dec 2023 at 10:52pm
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 7:00am
Sounds like you got some fine China
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 7:07am
hmm.. 'did not fit well'....
 Chinese use METRIC, so probably designed for 6mm  tubing NOT 1/4" tubing.
simple test, cut power to motor, does air pissssssssssssssssssssssssssssssss out at the nut/tubing connection ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 8:09am
 Hey Steve,,,I agree with you on the correct flow of the little line and most likely the diaphragm is leaking thru.
 Ole Jay is correct as well on the different line size as I had to emery cloth the chit out of the 1/4" copper tubing to get the steel nut and ferrel that came with the pressure switch to slide on the 1/4" copper tubing,,,,and I am VERY PIZZED OFF that the Mfgr did not include instructions as to the line size differences AND even more pizzed off that after looking in Lowes, 2 Home Depots, Two other Hardware stores and a True Value trying to find the correct size of tubing,,,NONE of the agents at all those stores had ever heard of a tubing size smaller than standard 1/4",,,,? BUT THEN,,,how are the USA customers suppossed to marry the USA 1/4" copper tubing to the chinese 6 MM tubing,,,,??????
 I generally consider myself to be Good Natured,, Casual Thinking,, Friendly and Easy going person,,,but this slight on the part of the  Mfgr is just too much and at first opportunity after Christmas,,,Amazon is fixing to catch an EAR FULL from ole Joe!!
 OK, Guys,,SORRY for the rant,,,gotta go take the chinese chit off and order an American made pressure switch,,,AFTER verifying with the Mfgr of the nut and ferrel size before ordering.
 OH,,,and IM4RACIN,,,ClapClap
Edited by desertjoe - 24 Dec 2023 at 8:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 8:50am
Joe.... its everywhere.... 10 years ago i had a 2002  truck that had a "bad spot" in the brake line that sat up against the truck frame under the seat area... I bought a 10,000 psi Compression fitting at NAPA for a 1/4 inch line .... Well the "FITTING" was actually 6 mm or .236 inch.. YEP... 14 thousands SMALLER than the 1/4 inch line.... Had to lay under the truck and sand off the OD of the pipe to get it to fit !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 3:25pm
Napa can get that pressure switch if you can find a competent counter guy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 6:16pm
 Well,,,I tried several times today to get thru to Amazon with NO LUCK,,,!! I was 43 in Que when I finally hung up But they will hear my rant tamorrow,, I KNOW it is not Amazon's fault but they should take the feedback to their supplier's,,so they can address theose issues,,altho they prolly won't do CHIT about it,,,,!!
 I never knew there was even a tubing line in that 6MM size and I'll wager that not very many others in this USA do  either,,!!
 As an Update,,,I found the problem right after removal of the pressure switch from the tank. The 4 screws on the diaphragm side of the pressure switch were loose caausing the leak. After tighting them, I did look at the diaphragm and it looked good from what little I could see of it, but it works as suppossed to and does relieve to atmosphere for bout 2 seconds  to relieve pressure in the line between the check valve and the pump,,,,
 Many THANKS for all the kind words,,,,!!ClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 6:28pm
sounds like your back in business !! ........ If your still interested in finding a section of 6 mm tubing , GOOGLE  6mm BRAKE LINE ... you can buy sections of it at AMAZON or Auto Parts stores... Come with various fittings on the ends... Some metric, some 1/8 inch pipe, etc..
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 6:29pm
  I hear you, Steve,,,at least I had the 1/4" copper tubing in a vice and using some emery cloth in two and it still took me about 1 1/2 hours to get it sanded down to where the dang ferrel and the nut would go on the line,,,, So,,, I can imagine how long it took you on your back and under  the trk,,,,
 I did go to Oreilly's and they had never even heard of the chinese  6MM tubing size,,,,what a mess,,,!!,
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2023 at 6:36pm
the two sizes are 14 thousands different.. I think in the US we have 1/4 inch... If it comes from CHINA it is "Metric 1/4 inch"  which is 6 mm..... 90% of the time it probably dont make any difference as long as the FITTINGS on the end match up... But if your using the TUBE by itself, that can be a problem..... many NEW trucks have gone to 6 mm brake lines.
Edited by steve(ill) - 24 Dec 2023 at 6:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2023 at 11:31pm
Joe, I KNOW your pain as I have also had that happen.  MANY hours later and the barn insides of blue........ I could go on and on about the reason for this, but I'm not in the forbidden forum room... Global economy myazz...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 6:19am
Since 99.44% of whatever we buy is/was Made in CHINA, you need to assume it's ALL METRIC.
The  best tool I've bought was a digital caliper ! They all have a mm/inch button....allows you to SEE the actual size of stuff AND convert from their number to NORMAL numbers !
What I hate are 'hybrids' like my Kubota tractor. Engine/drivetrain is 100% Metric(Made in Japan), loader and backhoe...Imperial ! ( Made in Georgia,USA...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 8:00am
  YES,,,I hear you,,,Jay!!  When I was working on my Mig's issues I decided to buy "American" and ordered a Complete  LINCOLN brand torch,,(whip) because it is such an important part of a mig performing well,,,,,,What came in the mail was a colorful box with LINCOLN stamped all over the box and after opening the LINCOLN box,,,,the nozzle, torch and all the small parts included were ALL stamped "Made In China",,,,,,,,,WinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2023 at 3:16pm
  Welll,,,My luck ain't holding up for CHIT, on the pressure switch for my shop compressor,,,,,
 I was working on the one ton andI started to hear the compressor cycling pretty regular,,and since I was not using any air ,,I went to look and you guessed it the friggin pressure switch was leaking possibly from the diaphragm,,,so I threw the breaker since ain't nobody at Amazon today  anyways,,they'll hear from me Tuesday,,,,,,CHIT,,,!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2023 at 4:01pm
Look on the bright side.... YOU didn't spend 10 HOURS tearing half the dash off YOUR Ford to replace a $20 piece of plastic the size of a sugar cube to make the PRNDL work WITH the gear shift lever, then ANOTHER 3 hours to put 10 pieces of dash back on....
dang, wonder if they still sell sugar cubes anymore ?
dbl dang, anyone remember sugar cubes ????
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2023 at 5:56pm
Got a box in the cupboard for my friend when she comes over and wants some herbal tea that she keeps here.  Can still buy it here although I'm surprised each little cube isn't individually wrapped like most stuff these days!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2023 at 6:43pm
Joe... 6 months ago i was looking for an electric fuel pump for a Side x Side.. Factory wanted $300.   ... AMAZON wanted $10. for CHINA .... I asked if they were any good.. Guy said " 30% are CRAP out of the box... so buy 3 (they are cheap) and you probably will get ONE to work long term " !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2023 at 11:18pm
 Yeah,,Jay,,the thing that gets me even tho it ain't Amazon's fault is that them jobs like you describe,,is always finish lashing up and then you got to try to solve where all them friggin parts are left over from,,,,!!!LOLLOL
  Yeah, Steve,,My GF has been trying to teach me to be more tolerant of others because Most times, you cannot effect a quick change anyway,,,,??Wink
 The thing I like about Amazon is that if you are a Prime member, you DO get special attention,,,,Wink On that first bad pressure switch after i talked to their CS rep,,, she had a replacement coming even before we resolved the questions about "What happened? Fact is,,the replacement arrived just two days after I called!! SO,,maybe the third time will be the charm and at least these have been on their dime except for my labor,,,,,
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2024 at 6:34am
Just finished replacing the rear brakes on my 1981 Parisienne Brougham.
Our local Canadian Tire Store has the Metric 6 mm Brake Line right along side their Imperial 3/16, 1/4, and 5/16 Brake Line.
G
This page was generated in 0.313 seconds.
