8550/4w305 Dyno test
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: 8550/4w305 Dyno test
    Posted: 27 Sep 2023 at 5:14pm
Hi a’ll!!
So I’m just curious on how many hps that engine cranks out on a dyno. I know the book says 305 hps but I read somewhere that a original one dynoed at 425hp whether that’s true or not…
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 7:11pm
The engine family that was used in those two models of tractors were in two cubic inch sizes: 731 cubes and 844 cubes. The 844 cube engine with an intercooler and proper turbo/injectors was rated at probably 450 HP at some point in time. The smaller displacement 731 engine may have been rated as low as 250 HP @ 1800 RPM for a generator power plant. Whatever the purchaser of the engine wanted the HP and torque to be is what was sold to him as such. In this case, 300 to 325 flywheel HP would have been the range the engine was set for at a specific RPM.
I M Fedup View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote I M Fedup Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 8:53pm
The 450 HP version. Might that have been the 844 designated as the model 25000?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 8:59pm
So they had two options of engines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 9:16pm
NO. Only the 731 was used in the 8550/4W305.
Edited by DrAllis - 27 Sep 2023 at 9:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2023 at 10:16pm
Hmm, would the 844 bolt right in a 8550/4w305?
Not that I have one but I’m just naming off ideas…
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 5:55am
Its been done
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 3:43pm
For those who aren't aware of the early troubles with the 8550 engine, the 2700 RPM high idle was the cause of the early and somewhat lingering engine problems. The first engine campaign involved replacing all the pistons, because they couldn't stand the RPM's.  Replacement pistons were beefed up in the pin boss area. Then, they found out the valve rotators were flying apart, which vomited little tiny valve springs into the oil pan, which would get sucked up by the oil pump. Both problems because the tractor engineers needed the engine to rev pretty fast so their transmission could hold up. This 731/844 engine was made for 2100-2200 RPM top speeds and the tractor division didn't want things that slow. So, for those thinking an 844 in an 8550 will work fine, just remember the transmission was made for 300 engine HP @ 2500 RPM and that's all. If the driveline would have held up to 400 HP, Allis would have made one at that HP rating, which they DIDN"T.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 7:03pm
Was the transmission for the 8550/4W305 specifically made for this tractor, or was it reworked from the 7000 series? If the transmission was specific to the 8550/4W305, why not make it heavy enough to start with?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 7:08pm
AWESOME knowledge Doc !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 8:44pm
Thanks Doc for your input!!!
If I ever got one with a shot engine (or needs rebuilt) I’ll know what to do…
I hope this encourages others to go Allis instead of some other brand.
I’d love to have one with twin stacks!!!
But money speaks first….
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2023 at 9:57pm
The transmission for the big-frame 4WD (8550/4W305) was a spin-off from the 7030-7080 transmission. Very similar trans case with much larger gears, bearings, shafts and a Power Director clutch that was about double the depth in clutches and plates. So, yes it was designed for and only used in the big frame 4WD chassis. The higher RPM thing I'm sure trickled down from the 7580, which got it from the 7080. So, pumps and driveline things in general got built around a "speed". In the beginning of the design, maybe the Sales Dept wanted a 250 eng HP tractor to sell, like an 8630 Deere was. An engine for that HP range would have been the 516 engine like the N-7 combine. Maybe plans got changed and they decided to go bigger at 300 HP instead ??  I don't know. I wasn't there. But, yes the transmission is definatley a spin-off/bigger version of the 7030-80 tranny with a drop box hung on the tail to connect to already existing A-C tractor axles. I've never worked on one of these big engines or trannys. Just know enough to be dangerous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2023 at 5:23pm
Thanks for the info. I supposed they didn't sell enough, to justify a whole new transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2023 at 5:35pm
Well, it was completely brand new. Not one single part interchanges with the smaller version in the 7030-80 tranny. It quite similar in DESIGN, but all the parts are thicker/fatter/wider/stronger. To me, it was never designed to work like a semi truck transmission....1400 RPM all day long with gobs of torque going thru it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2023 at 9:06am
Sorry Doc, I guess I misunderstood what you meant. That makes sense.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 1:35pm
Im not taking issue with anything you said good Dr. I looked at tractor data and it said the steigers were rated at 2100. Makes me wonder how they held up
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 4:19pm
I don't know what torque numbers or HP numbers and any changes that may have been made to the transmission for that particular Steiger application. Obviously Allis didn't want their rated speed that low and it may have only been for the hydraulic pumps they chose to use. Can't tell you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2023 at 11:05pm
I don’t know much about them but I love learning!!!
I have a 7580 service manual (thats where I fell in love with them) I got in a package deal…
I would someday like to get one (not like I have anything big enough for it to work with)if the right deal comes up…
jdeere562 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdeere562 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 3:06pm
I was working at an A/C dealer during those upgrades. I did all of them on the single 8550 they sold. What a pain! Had to work sitting on the tires, a ladder, or standing in back of a pickup truck. Plus the heads and manifolds were so heavy that a lift was needed.
After the piston update, the tractor came back in the shop with a rod knock. Figured I must have screwed something up. A/C sent out factory rep out to help me tear it down. He was blowing thru oil passages and stuff. I tore the oil pump down, that was what failed. Whew!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 3:10pm
I forgot about that "update". It too was in a way related to the extra engine speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdeere562 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 4:00pm
About where is your location DrAllis? I was working in Audubon, IA during the updates. We had Joe Dullard as a factory rep.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 4:57pm
So are the after market kit “updated”?
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 8:59pm
I owned and farmed with a 8550 for 20 some years. The 305 is the gross engine horsepower. AC marketed them as having 253 pto horsepower, which mine easily achieved the couple times I had it on the dyno. I updated the valve rotators to a CAT part number which are superior in design. AC should of used the proven and much more reliable 844 cubic engine, but from a cost standpoint I understand why they did what they did. I also tuned the injection pump to the specs. of the 4W305, which helped wiith upper driveshaft vibration and my peace of mind. I also have a 7080 and I could tolerate the 426 spinning that fast, but running the 731 @ 2700 hi idle , never seemed right to me. Just some of my many experiences, Mike
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 9:33pm
My time in the Delta in the 70's and S.La was blessed by having a couple of service reps, namely Billy Cruse who was close to Dahomme Plantation who had a bunch of 8550's. He followed the units closely and knew of the issues Doc mentioned. He had the farms remove weights and then lowered the RPMS and made sure the  CV joints were greased every 4 hours with long fiber high temp grease.  (many were changed out for cardan shafts that Paul Gain in Des Arc Ark developed) They ran so many hours the injector lines failed because of line erosion from the inside.  We followed his lead below I-10 and the Gay Plantation  had equally good success.  Allowing some wheel slippage took some off the strain off.  We didn't get farmer complaints because the competition  - all except Versatile  who seemed to fair better - had major failures in tranny's, planetaries, and even axle bearings.  Deere had 'fix as fail' programs - I was friends with the Deere dealer at Eunice La and what he showed me was unbelievable as to carnage done to the Deere 4WD of the era in S. La. He 'fixed' the Deere's before a sale of a new one.  $14,000 in parts alone he said .   The conditions in the South in the Delta were tough on power trains.  The two wheel drives faired not much better - we signed up Abel and Son in Welch La due to the failures of the big Case rear ends.  I don't know that we failed an Alliis power train except torque limiters in my time there.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 10:03pm
I purchased a set of used piston's from Paul Gain. Still have his add that I cut out of farmers hotline. I got over 2000 hours out of them. He also came up the CAT valve rotator, replacing the inferior oem's from AC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 11:50pm
Keep it going!!!
This is showing to be really good!!
It’s almost getting to me needing to change the title…
There’s getting to be a lot of information and things to think about when someone get one of those machines.
Thanks everyone!! This is what some need to hear before repowering or doing something major.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 7:39am
Just for reference here, this engine family was bought by AC in 53 from BUDA.  When the crawler line got the engine in 1955 replacing the 6-71 and 6-110 detroits,  these engines were turning 1700 rpm in the direct drive machines and 1800 in the converter crawlers.  HD16 and HD21
I will add that we run 2- 8550's as our main tillage tractors about 20 years now.  We generally run them about 22-2400 rpm but we also run smaller implements faster and dont lug them.  36ft field cultivator is biggest thing we've got.  32 ft disk and 800 bu grain cart.  no engine problems but we have been into the dropbox to replace the output gear on 1 and the other we replaced the bottom drive shaft that goes to the front and back axles.
Edited by CAL(KS) - 05 Oct 2023 at 7:41am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 9:16am
I've had an 8550 for about 7 years now. It's primary job is pulling my 28 ft concord air seeder 28 ft doesn't sound like much, but it's a load for it. Concord has Dutch openers which deep band anhydrous and pull hard. Hook on a 200 bushel seed cart and an anhydrous tank, and it's taking some more power. And the hydraulic driven air seeder fan robs a little more yet. I did have the torque limiter lunch out on it a couple years ago. A somewhat local guy with a farm shop replaced that for me for 2,200 bucks. I called that a gift. One thing that I never noticed about this tractor until last spring, was that the left front wheel only has one donut weight on the inside; all of the rest have twoo. Who does that?? Was thinking that I should go looking for one more weight for right front, but after reading all of this, I think maybe I should remove one weight from the other 3, so all four have only one. Spinning out isn't a problem with it anyway. Just about have to be in 3rd gear, low range, PD low before it'll spin instead of powering out. Less weight probably would add to longevity of the driveline.
    I developed another concern with it this summer as we were using it on a silage bagger, and that is that it won't stay in reverse. I am hoping that it's a shifting linkage problem. If its deeper than that, I may freak out.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2023 at 8:09pm
We got a call one Janurary at the dealership from Dave Arps from Memphis region. He ask us to pick up the 8550 at the Loretta Lynn Farm and do what was necessary to pull it in the new 4wd class at the National Farm Machinery Show at Louisville. Kind of stunned and knowing a tad about pulling I ask him why - it wasn't going to be pretty. He said he had some information that we would not be embarrassed - gave me the # to Terry Wood at the engine plant .  Later I found out the information came from Jerry Baird who worked for AC and was on the pull board - he was instrumental in making the pull as famous as it was and safe as well. So we did, and had an interesting time on the dyno - the larger M&W -which would not hold the unit as it tried to flip the dyno as it maxxed out. Terry advised us to loosen the set screw on the top of the pump and run the screw to allow the rack to travel until the engine went 'sour' which meant it had gone into cranking reetard.  We did but I did not lock the plate one time trying to find the max setting - the 8550 almost died - black smoke came out and it sounded like the engine was blown .  We were relieved to find the stop plate had vibrated all the way back- a little more playing and we had it set. We had to remove all the weight we could from the rear and add to the front but we could not get to he % we wanted w/o major surgery.  We added two exhausts and frame to hold them,  fabbed a hitch to specs and off we went - along with another 8550 we set up which belonged to Mac Bagget from around Springfield Tn.  I don't remember what gear we ran but we didn't phase the engine RPM which never reached 2600. I was told not to shift but with the sleds of the day which did not drop the pan we hit high range button and still spun out.  Could have gone up 2 more gears. We just didn't know as we were rookies.  We placed 5th behind 2 Versatiles with the 903 Cummins and an 8550 that was really hot and all were veteran pullers.   Mac's 8550 was 7th I think.  Hey - we got a check ! ( a fraction of the investment )  My plaque burnt up in the fire.  That was one in the 'bucket' .
ThatTractorGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThatTractorGuy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2023 at 6:08pm
That's quite a story! Wish I could have seen it. You said it placed 5th, but only mentioned 3 that beat it. Do you remember what the fourth was?
I'm writing about this kind of thing in my tractor pull novel....
But without faith, it is impossible to please Him, for he that cometh to God must believe that He is, and that He is the rewarder of them that dilligently seek him. Hebrews 11:6.
