N5 unloading auger Drive Shaft
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: N5 unloading auger Drive Shaft
    Posted: 24 Sep 2023 at 1:07am
Looking for N5 unloading auger drive shaft.  Need tube end that is on the bin auger. Or at least just the yoke... (7)10323722 I think...Thanks...Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2023 at 8:09am
Dale... i have had real good luck with these guys on PTO parts not available at local Tractor Supply... The FIRST thing you need to know is the BEARING DIAMETER of the U JOINT... That tells you the SERIES of the parts... Could be 1-1/8 , 1-1/4 , 1-3/8.. etc..
Here is the common 1-1/4 bearing size parts ( SERIES 35)..... once you know the SERIES, you can scan down the list and find a YOKE that has splines, hole, keyway, square drive, etc.
Edited by steve(ill) - 24 Sep 2023 at 8:10am
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2023 at 10:15am
have a n5 for salvage
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2023 at 1:14am
Yes, Steve it is 3500Series...Sure it is 1.25 bore.. Talked to Weasler..  802-3520... 10-45 steel as it gets welded to the shaft.. Shear pin hole and no keyway....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2023 at 11:12am
I think I may have found the yoke...John Deere OEM??
