7000/8000 series pto seal
gleaner1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gleaner1 Quote  Post ReplyReply Direct Link To This Post Topic: 7000/8000 series pto seal
    Posted: 21 Aug 2023 at 7:00am
Turns out both my 7030 and 8050 the pto output shaft seals are leaking.
As I’ve never done this repair before im assuming one has to drop that pan and get up inside to remove some snap rings to get it out?
Thanks ahead for any tips.
ALLIS CHALMERS "The color is orange"
8070nc View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 7:47am
I did it 35 years ago on a 7045. We left a pto shaft too long on a new rotary cutter and it put pressure against the pto an took the seal out. My point is I dont remember enough to help you the fact that I did it at a tender young age without a service manua I know you will get along fine
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 9:53am
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 8:31pm
Be sure and drop the oil, the cover underneath, the night before, and let it drip overnight.
