Wanted: Hydraulic drive sickle mower. |
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2259 |
Topic: Wanted: Hydraulic drive sickle mower.Posted: 06 Jul 2023 at 9:15pm |
Looking for hydraulic driven sickle mower and valving ..
The closer to Pittsburgh Pa. the better. PM me with your phone number and best time to reach you. Thanks in advance . Any brand. Edited by Macon Rounds - 06 Jul 2023 at 9:16pm |
Posted: 07 Jul 2023 at 8:24am |
What are you going to run it with ?? Not sure how many GPM's it will require and an oil cooler too ??
Macon Rounds
Posted: 07 Jul 2023 at 9:18am |
Just the aft section of a rig like this....
I have seen several industrial sickle mower machines that run hydraulicly.... Just need to find a complete unit and non running tractor. 😕 Will be running with a series IV tractor... But will probably need to to adjust hydraulic pressure/flow independently from tractor RPM so as to sync. PTO driven front sickle and rear hydraulic driven mower. Will this EVER happen ??? it's on my bucket list. ![]() ![]() Edited by Macon Rounds - 07 Jul 2023 at 9:22am |
Joined: 11 Sep 2009 Location: illinois Points: 89286 |
Posted: 07 Jul 2023 at 12:57pm |
Ben... after reading several of your posts, i have determined you have WAY TO MUCH time to think up projects !!!
Posted: 07 Jul 2023 at 2:42pm |
Well, you can't just adjust hydraulic pressure and flow to what you want. Hydraulic pump flow is directly tied to the engines RPM, so that goes down the drain right away. If the mowers are of the same/similar brand and model the PTO speed/strokes per minute are identical as it is. Just connect with the extended PTO shaft and run them both.
Macon Rounds
Posted: 07 Jul 2023 at 6:29pm |
thanks Doc.
I'll take that into consideration. |
Macon Rounds
Posted: 07 Jul 2023 at 6:32pm |
Glad you guys are appreciating my posts and pictures....
Gives me more incentive ! |
Daniel Wills
Posted: 08 Jul 2023 at 6:46pm |
If you need help with transportation services for any of your equipment please feel free to contact me at 667-290-9238
Best Daniel
Macon Rounds
Posted: 09 Jul 2023 at 9:58pm |
still searching ...
Macon Rounds
Posted: 16 Jul 2023 at 10:26pm |
still searching ..
