175 diesel front end bushings
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 175 diesel front end bushings
    Posted: 27 May 2023 at 3:03pm
Working at tightening up my front end and there appears to be a bushing in the diesel engine adapter plate for the rear bolt to hold the back end of the axle assembly. I cannot find a part number in the agco parts book. Has this been added or should a part number be available? Thanks
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 5:47pm
They don't show one with the front axle or the diesel engine adapter plate. I have no experience with the Perkins engine installations in those tractors. This I know: if the axle rear pivot bolt nut was T-I-G-H-T like it should have always been, there would be no wear whatsoever on that bushing. Over the decades I have tightened that rear pivot bolt on D-17's thru 200 tractors for being loose and I've never had one re-loosen that I know of. They must be TIGHT !! so they can't start wallering out the hole !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 6:39pm
how about measure the bore size and bolt size and see if it is WORN, or room for a bushing... McMaster Carr and others will sell various bushings.
Edited by steve(ill) - 27 May 2023 at 6:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 8:15pm
Steve that is the path I figured I would be going. Thanks
Allis Express
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2023 at 8:31pm
if the hole is just wollared out ... and possibly not round... I have used an air powered die grinder to cut / enlarge / round out the hole before installing a bushing.... easier than removal / drill press.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2023 at 9:52am
Hole is good. Just a worn bushing.
Allis Express
