HD6G 344 valve spring broken |
doctorcorey ![]() Orange Level ![]() ![]() Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Apr 2023 at 11:15am |
Well I got the loader out yesterday, and worked it for a while, and then I picked up this sudden miss, exhaust popping, and noise. Scoped it down to the number 3, and pulled the VC this morning. Broken exhaust valve spring, #3
![]() ![]() Edited by doctorcorey - 09 Apr 2023 at 11:21am |
Semper Fi USMC 1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
That's All Folks!
I don't have any Allis manuals. Found that via an online search. I wouldn't replace a single broken exhaust spring myself, but would replace them all.
That's All Folks!
Yes, I'm replacing all 8. Probably pull the head next winter and do a complete valve job.
gemdozer ![]() Orange Level ![]() Joined: 17 Sep 2009 Points: 1058 |
I should have 24 spring valves
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34146 |
Corey, If Memory Serves, or IIRC, there is ONE and ONE only Rocker Arm support or retainer bolt cut down for, that is the Lube Oil Supply off the rifling that feeds the head, is possible someone assembled incorrectly.
Edited by DMiller - 10 Apr 2023 at 1:45pm |
I recheck this morning and found 3 injectors AKB 75S
Just for the sake of posterity, I am posting a part number for a valve spring that will substitute for the AC 344 engine, with either single or dual intake valve springs. Maybe it will save some one else the frustrating hassle of trying to find interchange numbers for this orphan spring. I ordered #474025242 from Ag Kits. Set of eight was around $60. They match the AC manual for installed height pressure, and pressure at lift .500. I didn't have a free length spec for the original, but the new ones have about .150" longer free length than the sacked out old Allis springs. Installed height pressure and pressure-at-lift are the real only important specs. On a side note, I received the springs on FedEx less than 24 hrs. after I ordered them. Impressive! Machine runs like a sewing machine now.
