D- 17 belt pulley question |
Al53
Joined: 31 Jan 2023 Location: St Lawrence val Points: 4 |
Topic: D- 17 belt pulley questionPosted: 01 Feb 2023 at 12:40pm |
Will a hydraulic pump off a series IV D-17, bolt on to the belt pulley location of a series I D-17? Is there some gearing that will make it not work?
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4930 |
Posted: 01 Feb 2023 at 12:51pm |
No , I am sure it can be done but be better off with a front mounted pump. Would probably have to swap parts from an existing tractor to make it happen
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7495 |
Posted: 01 Feb 2023 at 2:43pm |
I researched that possibility many years ago. Of course the pump will bolt up to the housing, but will it work like you want? NO. The series 4 torque tube had to be redesigned inside for the side mount pump to work as intended.
