(2) G’s, unstyled WC and WD45 for sale |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9317 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jan 2023 at 6:40am |
1948 and 1949 G’s for sale. One is complete and running with all new tires. I have a plow and a full set of cultivators which may be missing pieces. I have 2 mechanical lifts.
The second g is a roller. It was rolled off of a trailer and bent the steering tube and steering shaft. I have most everything to complete it my bus one rear wheel center and a new steering shaft and tube. It has new tires on front and a pair of used tires I bought. The engine block is busted where the draw bar attaches but I have a spare block. 1938 WC. Has rear disk wheels ready for paint and a pair of used tires and tubes to go on them. The tractor was completely disassembled cleaned and primer Ed. I went through the rearend and put all new seals. I took 3 transmission tops to build a good one. I took 3 front end pedestals to build a good one with a couple new bearings and races. I have the front hubs blasted and painted and the front disk rims blasted and painted. It has a very nice manifold blasted and painted. The motor ran very well before I started the restoration. I only removed the pan and valve cover so I could inspect and change freeze plugs. The motor is back together and bolted to the tractor everything is in primer and been sitting a few years. I have hundreds of hours in this one. I have a 1954 WD45 for sale. Very good running tractor. Has a new gas tank. Tractor needs one hydraulic hose which I will replace soon. Could really use paint. I also have a 1984 Ford 1900 4x4 with a loader. It’s been around the block. Starts and runs good good tires doesn’t start well in the cold. If you need pics or information call or text 479 244 5216 |
I also have a 2 bottom SC plow and SC blade with box blade ends to go with the WD45
Bumping this for a couple days. If I don’t get any interest on here I’ll then put them on market place.
I’d much rather sell to someone on here that I can trust. |
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
whatcha askin on the 45? and Location in Ar?
I’d like to get $2200 for it with the plow and SC blade. Located in North West Arkansas. I can send pics to a phone.
$3500 for both G’s and everything that goes with them.
2200 for the WD45 with the plow and SC blade with box ends. $1200 for the WC $4000 for the 1900 Ford sold Edited by Thad in AR. - 24 Jan 2023 at 3:35am |
I had the G up and running. I may have to get the starter rebuilt.
I have video for anyone interested |
