7060 Blow by tube mount
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Blow by tube mount
    Posted: 11 Jan 2023 at 7:24pm
I removed the blow tube mount at the bottom of the engine a couple of years ago when I rebuilt the engine and apparently I forgot to install it, tube was in place just no bottom mount and now I can’t remember how it goes on, can’t seem to find anyplace in the area that would take a bolt to mount it, any pics or explanation would be helpful, thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 7:31pm
One of the oil pan bolts.
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 7:41pm
It bolts to the bottom side of the oil pan, you just need to remove the corresponding bolts and reattach. The round hose clamp will then be parallel with the bottom of the engine block, slide the vent hose through and all will be good.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 7:41pm
I can check my 7050, maybe get a pic.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 8:07pm
Alrighty makes sense, thanks for the replies!
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 8:21pm
You'll be able to tell by the lack of paint on the pan rail.
