Damaging rim lip removing tires?
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Damaging rim lip removing tires?
    Posted: 09 Jan 2023 at 11:42am
I was removing old tires from some 1939 B front wheels. Despite my best efforts, I ended up bending the rim lip in a couple places using my tire irons removing the tires. I was suprised how malleable the metal seemed. And yes, the tires are very old and stiff.
Is this typical?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 12:23pm
I have never bent a rim removing the tires.
I have straighten several rim lips that were damaged in use.
I have  had tires that were so OLD/ HARD/ BRITTLE that they literally tore up the beads trying to pry them off the rims ....... but i never bent the rim
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 12:27pm
I've only ever bent lawn mower rims. they are soft enough to bend just bend them back. I've had some that were so hard I couldn't get them off a Sawsall makes short work of impossable tires.
Edited by Dakota Dave - 09 Jan 2023 at 12:29pm
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 2:39pm
My tire guy (son) dropped by.   After saying the problem happened b/c no rubber lube, I lubed the tire and watched him work (he did this for a living). Guess what? He bent a lip as well even using a 3rd tire iron - said its routine on these tiny wheels with stiff sidewalls.
My conclusion: if the front tires need changed after 40+ years, cut them off or be ready to straighten the rim lips afterwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 4:01pm
lube helps 100% on tires that will FLEX... all the lube in the world dont help on hard/ brittle tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 2:24pm
Some tractors I have bought over the years have had dented/bent rims.  It seems that some people do get overly ambitious when it comes to mounting/dismounting tires.  With the swing of a sledgehammer, rims can dent pretty easily.
I take mine to my fab shop to fix.  They heat it up and hammer it back into shape.  Comes back as good as new.
This page was generated in 0.172 seconds.
