Field cultivator/ chisel plow D17
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Field cultivator/ chisel plow D17
    Posted: 31 Dec 2022 at 8:34am
Looking for something for spring tillage. Would like to chisel plow for deeper tillage, but, thinking might be asking to much from D17 gas. Figure 3 shanks would be all I could pull, so kind of a waste of time. Wondering if something like shanks from something like an IH #45 field cultivator would work. Hoping 7 shanks would work. Or would 5 be the most? How deep will field cultivator shanks dig. I'm leaning towards pull type not mounted.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 8:47am
Depends on the soil type and moisture etc, but as a rule, a field cultivator is going to be somewhere between a scratch and a couple inches as a first pass in the spring. When I use mine for finishing I go about 4 inches but it won’t dig into something undisturbed.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 8:57am
your best bet would be to hire a neighbor with his big tractor to do it.                   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 9:34am
Well, they made a one prong subsoiler for the WD/WD45 back in the day. It went pretty deep, like maybe 10 to 12 inches. I'd suspect a good D-17 (meaning good HP, good rear tire size and tread and enough weight to have traction) should probably pull TWO prongs as a deeper tillage tool. As far as a field cultivator, about the same width as a tandem disc, like 10 or maybe 12 feet. The wider the field cultivator sweeps or the deeper you go, the harder it pulls. How many ACRES are you working on ??
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 10:10am
Also the sweeps on the field cultivator will make the difference in how hard it pull. I got a IHC 45 field cultivator little over 12 foot wide I brought at a farm auction and used it for a few years and I changed out the sweeps on it with new sweeps from local CaseIH dealer ( they were cheaper from them than a couple co-ops ). The new sweeps pull a lot harder ( new sweeps was turning a lot more dirt than the wore out narrower sweeps ) and I had to use the cultivator on a different tractor that was little more horsepower and weight.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 3:40pm
mack has a fair point. vertical tillage with a ripper pulling deep can break up a hard pan. Seems to me when i have that custom done, wet spots seem to disappear . depends on your soil type but all the field cultivator does for me in new york is bring up rocks to pick
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 10:24pm
I have 3 acres of pumpkin ground on rented land. Gates restrict getting large equipment to it. Most years I get it plowed in the fall, but some years, like this one, frost beats me. Only got about half of it plowed.
Was planning on spikes, not sweeps. Right now the best I have is a 'green' quack digger. I have done spring tillage with my disc. But, that takes 4-5 passes to get the depth I need. That many passes starts compaction. I was hoping to find a way to eliminate a couple passes.
I plant using a waterwheel transplanter, so the ground needs to be fairly loose to a depth of at least 8".
I would love to have one of those 3 shank snap coupler subsoilers, but I haven't seen one of those within 500 miles of me.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 11:45pm
Regular plow was 10hp per bottom and chisel was something like15 to 20hp per shank. You can always remove shanks until you can pull it.
I've gone no-till Regenerative Agriculture  path so plows are evil.
Plant winter rye as your herbicide, plant pumpkins into the green rye and then roll the rye to terminate.
Bean guys terminate after beans are at V2, corn after emergence.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2022 at 11:55pm
You must run a poor field cultivator.   Both my current field cultivator and the finisher I had before would stay in the ground fine if I dropped them into unworked bean stubble. The trip force on the shanks of a newer FC is fairly stout.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 4:36am
Lii late this year, but try planting tillage radishes as your CC...Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 7:50am
Bean stubble ground is usually quite mellow and my FC would likely work pretty good. That’s why I said it depends on many things. That’s also why they make heavier tillage tools. But thanks for jumping on a chance to judge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 9:30am
Won't work with a waterwheel transplanter. Ground has to be loose, like it has been tilled to a depth of 8".
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 11:10am
Maybe this will help some of you understand what my goal is. This is my waterwheel transplanter. There is one 6" spike on the big wheel in the middle. That wheel is 5' in diameter. It pokes a hole every 15'. There is no down pressure on the wheel. Water runs out of the wheel, into the spike and fills the hole with water. The rider on the back then places a 3" dia x 4" tall peat pot with a pumpkin plant into the hole. As the water soaks in, dirt settles in and covers the pot.
When weather permits, I plant rye in the fall. I use it for weed control and as a plow down fertilizer. As a plow down, I let it grow to 6-8" then dig it in. Even as a plow down, have had good luck with weed control. Was having an issue with field bindweed. The rye has eliminated about 90% of it without chemicals. I broadcast it at a rate of approximately 5bu/ac, then likely drag it.
I want a chisel plow or field cultivator to run ahead of the disk as a vertical tillage to loosen the soil, so it won't require as many passes with the disk.
And yes, before somebody brings it up. A tiller would achieve my goals with one pass. But, my goal is to hopefully in the future expand to become a commercial grower within the next 10 years. Imagine trying to run a tiller across 40 acres.
Edited by truckerfarmer - 01 Jan 2023 at 11:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 12:16pm
Well, I’ll be honest, I’m not sure what you need to do. Actually I think a tiller would be a terrible choice. It would seem great for a year or two, but likely after that compaction would be a problem. But I don’t have knowledge of how your soil responds.
You say vertical tillage, but nothing you mention as on option is vertical tillage in my understanding of the matter. I’m not attacking you or trying to be a jerk, just saying what I think to be the case.
Since you plow this down over and over, perhaps a field cultivator would work, although I have a hunch you’re going to be fighting compaction soon if not already.
Of all the things mentioned, to me I think a chisel plow sounds like the best option. Or a subsoiler every so often used with what you’re doing to fight compaction.
Whatever you choose, good luck I’d be curious to know what works best and why.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 1:39pm
I know nothing about pumpkin farming. Why does it seem that what I find on youtube is everyone planting seeds and you are planting living plants? Must be a reason. What is it? Seed planting looks simple for ground prep VS the transplanter.
If nothing else I would try to come up with a strip till device to work the row only for transplanter. What am I missing?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 1:59pm
I'm going out on a limb here, and guessing that your rows are spaced fairly far apart. Get one strip till unit, make a 3 pt bar to mount it on, and just till up where your pumpkin rows go, and save the fuel and everything of tilling the 99 percent of the ground not used. Just a thought, I'm not there to see your situation, so maybe that's not an option, but just throwing that out there.
Darrel
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 4:16pm
Won't help this year but i would consider a different cover crop. Radishes with their deep roots would work better at aerating your soil than rye
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 4:45pm
Could you find a snap coupler row crop cultivator, remove the gangs, find some shanks from a 100 Deere or 55 IH chisel, and do the necessary modifications to attach them to the cultivator frame?  Wouldn't be a factory set up, but just might work.  Could use either spikes or sweeps as necessary.  Just an idea, Smile
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 6:12pm
I would just find some shanks and build my own, I’m doing the same this spring for cultivating my pumpkins. I can’t find a decent row cultivator for what I’m willing to pay so I’m building one from an old glencoe field cultivator. For what it’s worth I would think a d17 would pull a 5 shank chisel. I pull a 16’ glencoe (I think around 30 shanks) field cultivator with a cart drag behind it with my d17 and a single shank subsoiler to 15” deep.
Edited by Travis2766 - 01 Jan 2023 at 6:24pm
190XT Series III, D17 Series IV, D15 Series II, All Crop 66 and a whole mess of equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 7:26pm
Here come spring ground coming out of beans is no looser than out of corn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 7:40pm
How big of a spacing between rows?
Could you do some sort zone till?
I remember grandpa had old trip cultivator he pulled with his D17 it couldn’t handle much residue but if you made a couple passes it would go deep enough.  C shanks by nature will want to pull in if you have enough weight and stout enough springs.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 8:40pm
How about an old Allis coil shank cultivator, would one of those work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 8:45pm
Make sure you test both seeds direct in the field vs transplanting.
Whenever I test cukes squash or pumpkins I find the direct seeded ones run faster provided I get the seeds in the ground by the right date. Here they must be in the ground the end of May to get a last rain, if a week or two later there might not be rain for three or four weeks. Make sure to test, you'll save huge money planting seeds over plants if you find the same results.
If your transfer planter is spiking the ground, run through the rye to plant, the ground is likely quite soft under the growing rye. One guy using alfalfa said he plants into it then knocks it down so his corn has a chance to outrun the alfalfa standing back up.
We loved pumpkins for the point in late Juneish they canopied over everything and we could stop hoeing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 12:27am
Yes the rows are spaced far apart. The rows are 15' apart with 15' spacing in the rows. 2 reasons for that. One, is it allows a couple more opportunities to cultivate as they vine out. Reason 2 is about 1/2 of the varieties I plant require a minimum spacing of 8'. One requires 12'. Not giving them enough space reduces yields. I like to plant in a grid so I can cultivate in both directions. If we are really good at keeping things in line, I can cultivate at a 45* angle. Most of them will fill that 15' space within 6 weeks of planting. This last year the pink ones sent vines out 20'. Cultivation is still the most effective and cheapest form of weed control in pumpkins. There are only a handful of chemicals approved for pumpkins. Only a couple for post emergence. Only one doesn't require hoods over the plant, and last time I checked, it was over $300/ pint. Yes, a pint, not a gallon.
I don't plant the cookie cutter 8# pumpkins that Walmart sells. I plant 15-25#, 20-30# and 40-60# pumpkins. If you plant the same as everybody else,then you have to compete with everybody else. We market to the people setting up the displays, not for the kids carving pumpkins. Although a lot of the ones we sell do get carved, because they come to us because we have something different than everyone else.
As far as direct seeding. We did that for 10 years before I built the waterwheel transplanter. To keep the spacing requires planting by hand. 100-150 hills would end up taking 10-12 man-hours. This last year putting approximately 225 seeds in pot took about 2 hrs. With the transplanter 2 of us put 211 pots in the ground in an hour and a half. Another reason direct planting doesn't work for us is wildlife pressure. One year we lost 60% of our plants to wildlife. Our seeds are treated and the coatings are bright colors that look like metal flake paint. Seagulls can wipe out a crop in one day. We gave up trying to grow sweet corn due to pheasants taking all the seeds. They go right down the row digging a hole about as big around as your thumb and take the seed. One year in a 300' row, they took all but 12 seeds. Couple varieties l plant are $.61 a seed. One is $.84 a seed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 12:30am
I'm in the same boat. Expecting to probably build my own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 12:34am
Yes that would probably work. Only downfall would be aren't they mounted not pull type?
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 7:22am
[/QUOTE]
Spike wouldn't penetrate deep enough to set the plant. We use 3" dia x 4" tall peat pots. The taller peat pots help prevent the plants from getting root bound. The hole needs to be around 6" deep, so that when the water soaks in the soil silts back in and covers the pot. Otherwise if any of the pot is exposed it will wick the moisture away from the plant and dry it out.
There is no down pressure on the wheel. Full of water, the wheel only weighs 150-200#. So imagine strapping a 4" x 4" x 6" tall spike to the bottom of your foot and walking across your lawn, and try to get it to go deep enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 7:31am
Maybe it would help you understand what I am trying to accomplish in soil preparation if you saw how a waterwheel transplanter works. There are several YouTube videos of planting pumpkins with a waterwheel transplanter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 8:42am
Whatever. You are far superior and better.   I get it.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 9:04am
This might be something like you need.  I don't know how deep it goes, but it will make the '45 snort.
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
