It's Orange - What is It ?
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Topic: It's Orange - What is It ?
    Posted: 30 Nov 2022 at 9:46am
Can anyone identify this machine ?
For the last thirty or more years, I see this same tractor at any tractor show I go to.
This particular photo was taken at Appalachian Harvest Festival at Renfro Valley, Kentucky, on 07-October-2017.
I think it has a Wisconsin engine.
I thought this would be an easy identification; but, when I think I am getting close, I am not even in the ballpark.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2022 at 9:51am
looks like an older version of the ECONOMY..... I had a couple POWER KINGS years ago.
Edited by steve(ill) - 30 Nov 2022 at 10:00am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2022 at 9:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2022 at 5:42pm
Thank You ! I believe you've hit the nail right square on the head !
Either the tractordata guy or some Economy owners have their wires crossed up.
In this example, the tractor has a sign stating it is a 1953 model; while, his information says the first year available is 1968.
In this example, the tractor you pictured says 1961 model; whereas, tractordata says 1964/1965 is first available, depending on whether it is 10hp or 12hp.
I wonder who is right.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2022 at 5:49pm
i think the shape of the HOOD in the front, and the motor size, both changed over time... ECONOMY was the company... Jim Dandy, Power King, and others were the MODELS.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2022 at 5:51pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2022 at 6:00pm
They started out as 'Economy'... manufactured by an engineering firm in Waukesha in like '46 or so.  They changed the name to Economy - Power King sometime after.
The early ones' bodywork was basically just a reshaped cooling shroud over the engine, later they extended the shroud back towards the fuel tank, eventually they went to a hood-over-engine design.
The components were pretty darned close to off-the-shelf surplus-type driveline and steering gear stuff, but they weren't weak by any means!
