a question for the pullers--tires
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: a question for the pullers--tires
    Posted: 01 Dec 2010 at 9:49pm
Can new tires work for pulling? I know you almost always use old hard tires with little tread so the lugs dont fold back and they dont rut up the track as bad. I am having a hard time finding used tires around here. I am thinking of some new firestion 23 degrees,14.9-28. I know these are good tires but will they work or not? I hate to spend $800 on tires if they wont hook. I know one guy who pulls an oliver, he tried a new set of COOP tires and couldnt get more that 75 ft down the track. Should I hold out for used tires?
dharpo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dharpo Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 10:02pm
new tires will work on a loose track pretty good not so good on a hard dry track. if you don't mind taking a grinder or planer to them you can take some off the top and make them a little stiffer. you could probably find some good used combine tires at the salvage yards for about half of new price.
AS LONG AS THERE ARE SHADE TREES I CAN BE CALLED A MECHANIC
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2010 at 10:44pm
I have a couple of 13.6x28's that are worn down pretty good. Mismatched, but not sure it would help or not? $80 for the set if anyone is interested.
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
This page was generated in 0.041 seconds.
