wd hydraulic don't go down. |
bikergreat1911
Joined: 22 Oct 2021 Location: new Bloomfield Points: 26 |
Topic: wd hydraulic don't go down.Posted: 18 Apr 2022 at 3:27pm |
Hello I can't figure out why the rams dont go down. If i crack a line to relieve the pressure they go down.. i have also read that you can screw the top valve in and they should go down. No luck, i have messed with all the thumb screws to no avail as well. Even took off the traction bost linkage and moved it around with know luck.. Please shed some light to this problem thanks.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5192 |
Posted: 18 Apr 2022 at 3:38pm |
What model tractor?
ZachD89
Joined: 24 Dec 2015 Location: Littlestown,PA Points: 703 |
Posted: 18 Apr 2022 at 3:51pm |
Read the title of the post. That helps alot |
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
MACK
Posted: 18 Apr 2022 at 8:26pm |
The screw In front of pump that screws out against bell housing, screw it all the way In. Arms should go down. Back screw back out all the way. Pump should work. If it does the same thing, pump needs to come off and gone through. MACK
bikergreat1911
Posted: 18 Apr 2022 at 8:47pm |
OKay i will try that. Thanks
