wd hydraulic don't go down.
bikergreat1911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikergreat1911 Quote  Post ReplyReply Direct Link To This Post Topic: wd hydraulic don't go down.
    Posted: 18 Apr 2022 at 3:27pm
Hello I can't figure out why the rams dont go down. If i crack a line to relieve the pressure they go down.. i have also read that you can screw the top valve in and they should go down. No luck, i have messed with all the thumb screws to no avail as well. Even took off the traction bost linkage and moved it around with know luck..
Please shed some light to this problem thanks.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 3:38pm
What model tractor?
ZachD89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ZachD89 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 3:51pm
Originally posted by WF owner WF owner wrote:
What model tractor?
Read the title of the post. That helps alot
37 A,37 Waukesha B,35 WC,38 WF,M crawler,49 WF,49 WD,53 WD45,39 and 40 RC,47 WC,41 B,39 B,48G,48,C,59D10,D21,IB,B10,B12,B208,B1,Roto Bale Loader, sp100 combine, allcrop 66, L3 Gleaner
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 8:26pm
The screw In front of pump that screws out against bell housing, screw it all the way In. Arms should go down. Back screw back out all the way. Pump should work. If it does the same thing, pump needs to come off and gone through.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikergreat1911 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2022 at 8:47pm
OKay i will try that. Thanks
