Adding loader joystick to 6080?
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: Adding loader joystick to 6080?
    Posted: 16 Apr 2022 at 9:32pm
Looking at buying a 6080 with a Koyker loader that is plumbed into the remotes. The tractor will be used for hay work so we need the remotes for rake/tedder, but would like to keep the loader and eventually add a 3rd function to run a hay grapple. Is there a power beyond port to tap into, or some other easy source to use to feed the loader?
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2022 at 10:11pm
Brake the line from remote valves to 3point. Run a line from remote valve stack to a power beyond valve. From loader valve to inlet of 3point valve.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 9:26am
Do you know roughly how much hydraulic flow it would have?
Jimmy
1982 6080
1992 R52 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2022 at 10:57am
Approx 12 GPM at full throttle.
farmerjohn827 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmerjohn827 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:20am
i just wondering if you were able to do the power beyond to the loader cuz i also want to free up my remotes in the back of my 6080
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2026 at 9:08am
