180 185 Rear Ends.
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Topic: 180 185 Rear Ends.
    Posted: 14 Apr 2022 at 1:04pm
I have always wondered how much heavier their rear ends were compared to the D17. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2022 at 4:14pm
A lot. You think that rear end is just a D-17 S4 or 170 but it isn't. They've stuffed a complete 190/190XT transmission inside that rear end case. The axle tubes are much heavier and bull gears twice as wide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2022 at 6:16pm
When I got my roller One Eighty puller- had Agent Orange - on the side, suppoedly it had a 4 turbo setup on it ? Dunno that is true , but pulled the final drives to redrill them and the axle splines had a quarter twist in them , never broke but sure were in a bind somewhere !
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2022 at 11:28pm
Thanks for the Information. I knew they were more rugged than a D17. Just didn't know you much. They are a very rugged designed tractor I do know that. Our 180 Diesel is going on 12000 hours. All original engine transmission and rear end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2022 at 6:40am
I'd go out on a limb and say 95% of any transmission problems with a 180/185 are due to gears being ground to a pulp when shifting, or run out of oil from a leaking PTO shaft seal.
