G Plow swinging
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: G Plow swinging
    Posted: 20 Mar 2022 at 9:24pm
In the final stage of restoration and I have mounted the plow.  When I use the hand lift, It swings inside and rubs against the lift mechanism.  I never had this problem before I took it apart.  I took lots of pictures while I dismantled it and it looks like I have everything back together correctly.  I recall someone had this same problem around a year ago, but I cannot find it.
Hopefully you can see in these pictures...
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 10:43pm
Myron, you're missing #13 in the picture
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2022 at 10:46pm
Ford 345C TLB
BobDinNC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobDinNC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2022 at 6:13pm
That was me asking this same question earlier and Joe had the information to get me on the path to a solution. Ended up having a fabrication shop make a replacement piece that solved the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2022 at 9:30pm
Never had a problem with it before I tore it down.  I will be heading to my local fab shop in a couple of days.  They are always happy to see me $$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2022 at 10:24pm
bet getting everything cleaned up let it pivot and swing easier, allowing it to hit
Ford 345C TLB
