H. DISSTON & SONS hand saw
Message Reverse Sort Order
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: H. DISSTON & SONS hand saw
    Posted: 01 Mar 2022 at 6:40pm
Thanks Dave, I'll have to check out the teeth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 6:18pm
Originally posted by ACinSC ACinSC wrote:
Thanks for the replies
I just wonder what this saw was used for ?
Hard to say from the pic, can't see how the teeth are filed. Crosscut saws are filed at a 45 degree angle, and every other tooth points a different way.  Generally set a little wider than a rip or pit saw, which is filed at nearer to 90 degrees, and each tooth is set just a little wider than the one in front of it. Pit or rip saws teeth look like a wave on the ocean, when viewed from the end, down the line of teeth. Pit saws also have deeper teeth than a crosscut, sometimes an inch and a half deep gullet. Yours looks like a crosscut, or a really worn down pit saw.( sometimes thrifty sawyers would convert worn pit saws to crosscuts)
Clear as mud?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2022 at 7:33am
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 6:47pm
At home we had one similar...maybe not quite that long and also had a handle on other end for 2nd person... also had the longer 2 person style... ... ... and we had a hay bale saw that was about 3-4 feet long...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 6:20pm
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2022 at 6:04am
That it was Dave
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 8:17pm
As I foggily recall, wasn't Junior's phone number BR549?  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 3:58pm
Originally posted by Dave H Dave H wrote:
Fortunately I was able to buy a replacement blade and with a little work with the cut off wheel and drill press, it works like a new one.  Wink
This comment made me think of Junior Samples when he had George Washington's hatchet. It was on it's 2nd head and 3rd handle but it was George Washington's hatchet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 9:57am
I had to go and check out my ole meat/butcher's saw.  It also has Disston stamped on the frame.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 7:51am
Not a very good picture, but here it is thanks to my favorite son . That's 3' rule on it. Thanks
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 6:20am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2022 at 1:31am
The last Disston I saw, was around 250CC, was single-man op, but had the second-man handle feature.  They have quite a storied history, and while they do not have the performance, ergonomics, safety, and efficiency of TODAY's saws, they certainly ruled the roost when they were new.  Imagine the cutting power if you put a pair of 880 Magnum cylinders on a common crankshaft, and used that to sling an 8-foot bar...  The sound and the fury...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 8:23pm
Lehmans Hardware www.lehmans.com still has the one and two-man saws listed but they are pricey.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 5:08pm
I would like to see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 2:28pm
Very nice of you Hubert . I can get my fav son to post a pic if anyone wants to see it . This one man saw has a brass medallion with the name . Don't see anything on the two man saw . THANKS !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 1:55pm
I have seen those and I still have one of Dad's two-man crosscut saws but I am not sure of the brand. We used one on the FFA forestry team many years ago. If you want to email or text me some pictures I will see if I can put them on here for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 12:40pm
Sorry , never have figured pics out . Pretty sure Dad bought this saw somewhere . He used to dabble in antiques . Also have a 6' two man saw that he had . Thanks !
Kansas99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 12:27pm
Got any pics for us?
and I bet if your dad ran that saw all the time needing the whole length of blade, when he spoke you said "YES SIR" LOL
Edited by Kansas99 - 26 Feb 2022 at 12:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2022 at 12:04pm
Have one that was in my late Dad's stuff . One man saw with a 55" blade ! Just wondering if any of you fellas have seen one like this ? Thanks !
