7060 Allis Clutch cable
Boyd122 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boyd122 Quote  Post ReplyReply Direct Link To This Post Topic: 7060 Allis Clutch cable
    Posted: 19 Feb 2022 at 9:54pm
Hello,
I have a Allis Chalmers 7060 5 speed with high low and PD Maroon belly tractor. Lately my clutch cable has become a pain and stretched beyond use. Does anyone know where to get one? I use the tractor daily and as my planting tractor. If anyone knows a part number or a cable that will work please leave a # or link for it! I appreciate it! Thank you in advance! God bless.
8070nc View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 1:10am
Bunker Hill Cables
866 434 0047
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 7:13am
Cable is 70269446..........two ball sockets are 70930435.........two fork bushings are 70269529.........one- 70929046 and one- 70929006.  AGCO will have everything. Bunker Hill will have the cable only.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 8:17pm
I got a Bunker Hill remote cable for my 7050 that I converted to 7060 heavy cable style. I ordered a 7060 cable and it was the right length and was the heavy one but both ends were too narrow where it slips into the brackets. Had to file the machined parts wider. It was a pain. I had two old but still good, I assume AGCO, cables that fit perfect.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2022 at 10:14pm
You're talking about a remote lever cable, right ??? not a clutch pedal cable.
Edited by DrAllis - 20 Feb 2022 at 10:15pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 6:14am
Right. I'm just relaying my experience using Bunker Hill.
Wink
I am a Russian Bot
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 5:52pm
I've seen the same problem that Lonn is describing on the remote cables too..
YZfarms1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YZfarms1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 7:46pm
yes, Bunker Hill cables is where i purchased both shifting cables for my 79   7080  restoration.  They worked perfectly.   Yours will too !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boyd122 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2022 at 9:12pm
Thank you! Thank you all, went to agco and ordered it all, they had the eyelits and bushings but have to wait for cable.
I appreciate the quick reply from you all!
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 3:08pm
My 79’ 7060’s foot clutch cable snapped yesterday after 44 years ~I think? I’m assuming cable is OEM, but I’m not original owner. It has 5600 hrs on it.
Glad I found this earlier posting to know all the necessary details. Anyway, “Thank you” to all those who posted info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2023 at 6:12pm
Do you have relationship with agco dealer. All the numbers supplied above are still available. If you don’t I can help you. Only numbers we have stocked are the bolts
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2023 at 2:06pm
Mikez, sorry for late reply. The great fall weather has allowed me to be busy planting winter wheat. Yes, I have two very good AGCO dealerships within 50miles. But thank you the same. If I can’t locate my parts needed, I’ll pm you.
