installing some trex patio flooring. |
tomNE
Joined: 13 Sep 2009 Location: dorchester, ne Points: 1225 |
Topic: installing some trex patio flooring.Posted: 18 Dec 2021 at 6:43pm |
i'm in southern AZ and the heat causes problems. I wanna install new flooring on the patio; thought about using plastic underneath the flooring for a moisture barrier. I think the plastic would desinagrate under the trex flooring. I'm thinking about using tar paper under the trex for a moisture barrier. I'm looking for opinions. there will be a solid plywood floor under the trex!
Joined: 11 Sep 2009 Location: illinois Points: 90921 |
Posted: 18 Dec 2021 at 6:52pm |
i dont think plastic under plywood would disintegrate... Think it has to be in direct sun light to have a problem..
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55314 |
Posted: 18 Dec 2021 at 7:02pm |
Be careful in choosing the product and the color. plastic lumber can act as a heat sink in sunny areas, and can broil your tootsies, if you walk barefoot on it!
tomNE
Posted: 18 Dec 2021 at 10:36pm |
carpet lasts about 5yrs and it's not in direct sunlight!
shameless dude
Posted: 19 Dec 2021 at 1:24am |
prolly best to go with a slate type flooring? that's about all i've ever seen down there.
tomNE
Posted: 19 Dec 2021 at 7:35am |
lots of slate floors inside park models but in 5yrs of wintering here; i've never seen it on a deck!
RingGeneral
Posted: 11 Apr 2025 at 6:40am |
Tar paper is actually a pretty solid choice under Trex in hot climates - it holds up better than plastic, which can definitely break down fast in that Arizona sun. Just make sure there's no trapped moisture between the plywood and the barrier. Also, if you're updating your whole patio, check out this website URL they've got some great outdoor sets that'd go nicely with new Trex flooring.
Edited by RingGeneral - 24 Apr 2025 at 2:06am |
