200 hight reduction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: 200 hight reduction.
    Posted: 11 Dec 2021 at 4:21pm
hello
Could we loose five or six inches if we let some air out of tires. Want to get it into garage to do some work on it. Figured I’d ask and see if anyone has done it before messing with valve stems lol.
Thanks
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2021 at 5:14pm
If it doesnt have a cab just take the muffler off to clear, in my experience if the tires don't have calcium in them the air can be left out to get in garage then air them back up once in the garage to keep from pinching the innertube drive as short a distance as possible with low air pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2021 at 6:47pm
You could get a mohel to take 6" off the pipe.  Won't help if it has a cab, though!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2021 at 8:26pm
yes sorry. Cab is what we’re trying to clear, and rear tires are loaded. I figured we’d put valve stem at top measure tire let air out tell see fluid see what we got.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2021 at 9:47pm
If they are full of fluid, you will have fluid coming out before you drop 6 inches. Unless they aren't full. You could get an adapter, valve stem to a garden hose and let some fluid out.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 10:13am
you can let them down real low even with fliud you do it with the stems on top  had to do that in the old shop  with 10 foot doors
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 12:01pm
See what a PIA fluid filled tired are !
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 2:35pm
See what a PIA small shop doors are.
BKarpel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BKarpel Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2021 at 8:07pm
Could make a stand on wheels to support rear end or drawbar support. Then remove the tires and push into shop. Alot of work but doable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 9:37am
Guess it depends on how bad you need to work on it. Be a good time for a friend with bigger building.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 10:47am
If your barn only has a Dirt or Gravel floor you could dig it out to get under/past your door.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 10:51am
I'd think you could sneak by with a couple of inches, but 6 is probably a bit much.
Edited by injpumpEd - 13 Dec 2021 at 11:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 11:44am
I guess you won't know til you try
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 4:06pm
lol thanks guys. We let some out tell we felt comfortable and we were like inch or two still to high. So we’re working outside. Funny my grandfather was a dealer here. Before they thought of cabs ha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2021 at 6:20pm
Yep: Most building doors were just fine when they were built 50+ years ago.
