Leak around D-14 gas gauge
Kip[NY] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Topic: Leak around D-14 gas gauge
    Posted: 23 Nov 2010 at 10:10am
Gasoline has decided to leak in tiny amounts from around the gas tank gauge on our '59 D-14 (only when the gas is up to gauge level).  Before this relative novice tackles this, what should I be considering and could this be as simple as a gasket?  While I'm at it, the float mechanism has never worked properly and when the tank is half full it usually shows closer to empty!  If I end up removing the gauge this would be the time to try to fix this too.  Neither problem is a "problem", more an annoyance that I'd like to spend some time on.  Thanks for any advice that you can offer.   Kip
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 11:03am
Kip, I had the same problem with my D 15, it is just a simple gasket that has deteriorated (cork I believe). My problem was the #@&*$%! slotted screws holding the gauge fast would not come out as they are to get to without removing the tank. anyway I sold the tractor before I replaced the gasket, so if I can find it I will mail it to you. Eric
MBwcenll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcenll Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 11:22am
The gasket is a flat o ring and is available from AGCO.  Hit the screws a tad and probably on the lower two you will need an offset screwdriver in order to remove the screws.  Or use a screw driver bit on a 1/4 or 3/8 drive ratchet wrench.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 12:37pm
I put a fuel bowl gasket under mine ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 1:31pm
Been there !!Yeah, some 'engineer' must have a been dreaming using 1/4-28 fine thread bolts !!! I got 3 out of 4 out ok....%&%&^% with the 4th !! Lucky me it's the top left and I can't afford to fill the tank(gas is $4.40 / gallon today).
I had to loosen off the 'control sector assembly' to get a screwdriver in there,straight on.Best to get a tight fitting slot,tighten just a tad, then back off.If there is ANY resistance,tighten a bit, then back off a bit more.Wished I'd had a bit more patience the first time.....
I got rid of the gas soaked cork float, put 1/2 of a 'plastic' one on from a Cavalier sending unit.Other 1/2 went onto my other D-14.
Made my own cork gasket,sealed up OK....Now if the price of gas would go down...I'd fillup !
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 8:08pm
  agco does not servie the gasket   they use an o-ring now  have in stock
   1-574-342-4545
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2010 at 8:47pm
My D-14 was doing the same thing.  You are right about it being a pain.  I ordered a new gauge from Norm and it is a nice piece. New seal and gauge and WHAT a difference knowing how much gas I got and I can enjoy a CHEAP cigar while mowing and not blow myself up.  Others have fixed the float but I did the replacement in mere minutes and got going again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2010 at 9:06am
While you have the gauge out fixing the gasket, replace the float with one that won't rot away. Call Kevin at 866-654-2855 and ask for an A-9313-C gas tank float. It's $4 plus the ride.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2010 at 6:33am
Thanks for all the help, guys.  I've ordered a new float and am working on a gasket so I should be in good shape.     Kip
This page was generated in 0.041 seconds.
