To The Semi Tractor Owners ?? |
Author | |||
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Nov 2021 at 7:01pm |
To those that run "pre" engine computerized rigs, at what interval do you change the engine oil ?? Is it based on a mileage regiment or an an engine hour routine like the old school farm tractors/ combines ?? Thanks
Sponsored Links | |||
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34161 |
Most anyone running larger Class 7 or 8 trucks draw oil samples and have them evaluated for change point. Not much anymore is by hour or mile.
TomC ![]() Orange Level Access ![]() ![]() Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1549 |
I changed mine every 12,000 miles.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5035 |
I retired from NYSDOT.
Our "large dumps" (a mixture of tandem and single axle trucks) were changed at 10,000 mile intervals. A lot of the miles put on these trucks was plowing snow and, in summer time, a lot of hours idling on job sites. While the truck was covered by warranty, new oil was used. As soon as the truck's warranty expired, they were switched to recycled oil. I worked for DOT for over 31 years and I don't recall ever seeing an engine wear out or ruined that could be blamed on the oil except we had a problem a few years back with oil pans rusting through (exposed to a lot of salt and calcium chloride throughout their life), until they went to composite oil pans. I see a lot of people spending a lot of money on synthetic oil. These trucks didn't even get new oil!
Thanks guys for your replies !!!
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8108 |
I know many change oil in the 15,000 mile range, even with today’s new ‘modern’ engines. On the frac fleet we have where I work, the engine oil is changed every 400 hours. The oil pans hold between 40-50 gallons of oil, depending on the engine. |
Can you elaborate on the "frac fleet" machines please ?? 40-50 GALLONS ?? , OUCH !!
The ‘pumps’ that are the heart of ‘hydronic fracturing’. Huge Diesel engines the run pumps all hook in tandem, that pump the water/sand mixture down hole to ‘fracture’ the rock that had crude oil impregnated in the rock formation. General range of 23,000 psi. Generally 20-25 pumps running on location(pad) at any one time.
victoryallis ![]() Orange Level ![]() Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Big difference in trucks that run 6 weeks at harvest than a OTR truck. My semi tractor runs a few odd days for wheat and oats harvest then as weather permits in October and November but if the weather doesn’t improve heavens knows when corn harvest will end. Mine gets an oil change late September or early October regardless of miles.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 42006 |
I serviced 5 OTR tractors in the 70's and 80's for a client - and set a 10 to 12,000 mile range on them . I got one unit at a time in as staggered changes of about 1 a week .
2 units had lube finder filters and changed them out every other oil change bit engine filters every time . On own dump trucks I changed about 6,000 miles as conditions of dust and dirt was more conclusive to quicker changes . |
Luberfiner filters were bypass filters, later filtration units eliminated the need of them if there ever was a need of them. Changed hundreds of those over the years where a few were left too long and the fibrous mass inside them busted out, dehydrated wood fiber.
Most would choke up early going into bypass on their own. |
Thanks Lars for the reply
![]() Edited by FREEDGUY - 13 Nov 2021 at 6:22pm |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54278 |
Google says 250-400 gallons...
Many years ago, I heard that they change the oil in locomotives with the engine running. Apparently there are different compartments and the oil can be changed by diverting to different compartments.
The EMD and GE diesels can be oil changed while running but generally are not as dilution occurs during the process old to new. Had V14 Colt Pielstick Fairbanks marketed diesels at the nuke I worked in, 450gallons oil with a 150 gallon add oil keep full tank. The big engines slobber heavily using considerable amounts of oil per year.
DM, is it true that there ARE 2 stroke diesel engine on a locomotive ?? I recently did work in a home of a retired "CONRAIL" electrician that said that such an "animal" exists on the current rail lines
![]() Edited by FREEDGUY - 14 Nov 2021 at 4:33pm |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12225 |
So, you don’t believe him?
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
Not only are they on rail lines, they're prevalent on rail lines. The GM-EMD locomotive prime movers are super-turbocharged two-stroke. The ones I taught on were four-valve head, full-authority electronically controlled fuel injected. The super-turbochargers are, as it sounds, a two-function device. A drive gear off the camshaft drives the compressor turbine through an overrunning clutch. Once exhaust pressure rises sufficient to pick up the load, the exhaust turbine spools up, and exceeds the overrunning clutch, making it now a turbocharged engine. They ARE two stroke, as the cylinders are ported for scavenging. OTH I don't recall if it was set up for upflow (into port, exhaust out valves) or vise-versa, I believe it was downflow, but I've taught too many others since then, but they were very well designed setups, and didn't discharge much lube oil under working conditions. ALL engines, and Diesel engines in general, will discharge engine oil, as a result of running. They do it most, however, when under little, or no load. Why? Because cylinder pressures are low, hence, pressure-based ring sealing force is nonexistant. Once above 40% load, they are really tight. The locos I taught on had a 500gal operating tank, with a 100gal feeder, they were designed to be maintained by the feeder. Oil changes in those were spec'd at 6000 operating hours, but samples taken on a weekly basis, and the eductor system pressure tested at same time as samples. If a sample indicated a loss of quality or increase of some contaminant, it was responded to accordingly.
EMD is losing out to GE which is using the old ALCO base design four stroke engines, Cleaner, more fuel efficient and more durable. They have also gone almost completely to AC motors and have stopped building Locomotives on DC circuit.
The EMD Four Stroke 1010 engine or H engine is current production line The Two Stroke 567 and 645 engines were the mainstay for Generations of Rail Engines and Barge Tows. |
I'm sorry, did I misunderstand something that was said earlier ? If so, I apologize to that poster
I believe Tbone was referring to the Conrail Electrician
Possibly,
On a side-note to you (DMiller) and DaveKamp, what is the HP rating of a locomotive engine ? Is it based on the same "ag" tractor rating as far as PTO/drawbar HP or based on mathematical scenarios ?? Thanks
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88194 |
people jump on you, because you say stupid stuff, and are an EASY TARGET !!
Go to the Net Freegas, you are embarrassing yourself as you can make said search if can make posts here..
I wouldn't jump on you if you were the last person on earth ![]() ![]() ![]() But seriously......you talked to a RR employee that told you something, then you come on here and ask DMILLER if it is true? WTF, so for some reason you didn't believe the guy who was a RR employee? And you could have googled what you asked in mere seconds, rather than waiting for a reply. . . .from a guy from MO! ![]() I used lots of emojis and typed real slow so you could understand.
The RR employee retired 31 years ago , seems like times "might" have changed
![]() ![]() Edited by FREEDGUY - 20 Nov 2021 at 5:14pm |
So you asked a guy who never worked for the RR for confirmation….
Ok. Happy thanksgiving to you too. |
All the specs are listed in the links I provided, Prime Mover engines are rated either in KW for Generator ops or for Shaft HP output as no drawbar on a engine. Is a Coupler on a Locomotive.
