H3 Industrial with orange block
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Topic: H3 Industrial with orange block
    Posted: 27 Sep 2021 at 10:32am
So after I finished pressure washing my newly acquired H3 Ind dozer some yellow paint came off and exposed some orange paint on the block. Did AC paint over orange engines before sending to Industrial line or is this probably a motor swap?
Thanks
1962 H3, WD45, B210
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 11:24am
I don't believe they were orange and then painted yellow to go into the H3. Original H3 gas engines have a mechanical fuel pump on the side of the block, close to the oil filter. This was necessary for operating the bulldozer on steep inclines. If your engine does not have the mechanical fuel pump it is likely a swap engine from a tractor.
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 1:12pm
Well it does not have a mech fuel pump. There is an embossed flat spot but no pump or blocking plate.  It does have a L27G stamped on that side and 149-1389 on the other.  Best I can decipher is it’s a 149 engine and like you said probably from a tractor.
Thanks
1962 H3, WD45, B210
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 3:06pm
You've got the right size engine being a 149 and in the event that you work in steep terrain you can always install an electric fuel pump, however, if your gas tank is full or close to full you'd likely never need help beyond gravity to supply the carb. Have fun with your H3, it's a fun toy.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 9:14pm
What is the serial number of the crawler. The later stuff had a 160 in it. Both will work fine.
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 2:44pm
The serial is 3897 so I think it’s 1962.
1962 H3, WD45, B210
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 6:27pm
That should be a 149 machine with oval muffler and dry air cleaner.
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 8:40pm
I have oval muffler but oil bath air filter.
1962 H3, WD45, B210
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2021 at 6:17am
You are correct. I just looked at mine again. It has oil bath.
This page was generated in 0.131 seconds.
