Forced air outside wood furnaces ?
Message Reverse Sort Order
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Topic: Forced air outside wood furnaces ?
    Posted: 05 Aug 2021 at 1:40pm
If you have an unlimited supply of wood or very cheap access, they work well especially if set up to load with loader bucket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2021 at 1:12pm
Neighbor used hot water type boiler outside and had exchange coil in hot air plenum on his Propane fired forced air furnace - had pre heat tank on water heater - but for control had another exchange unit in attached garage which acted as wild zone and diverted boiler water to circulate through that when house didn't need heat but boiler was still fired high .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2021 at 4:41am
Been seeing a number of the older forced air wood furnaces at the local HVAC company, most have cracked heat exchangers they said were due to wider temperature cycling and wood moisture issues as opposed to LP or NG furnaces.  Were too costly as near to expense of complete new unit to just replace the heat exchanger.  Boilers can have freeze issues if not kept running in winter where if have to go elsewhere for a period of time can freeze and burst piping near the boiler, also need to purchase temperature control system with these(Optional) or end up too hot in open run regions and can damage concrete or discharge coils.
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2021 at 11:11pm
We built a shed at my parents house around the outdoor boiler with the boiler tube end sticking out. Easier for maintenance. Nice loadind the wood end inside the shed. You can take nice long hot showers because it has a heat exchanger for the water heater as well as one for the forced air furnace. Dad said if we had built it 16 x 24 it would hold a winters worth of wood. Dad only wanted a 12 x 16 when it was built.
Edited by 1951WDNWWI - 04 Aug 2021 at 11:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2021 at 9:37pm
everywhere i've seen people that have them, i don't ever see where they keep the wood under cover, always covered with snow or wet from rain. i guess that if i was to have one i would put a roof over it with the wood under the roof too, sure should make it easier to load each time. i have thought of placing a shipping container outside with the wood furnace in it, filling the rest of the container with the wood. could have it blow hot air or pump hot water either way. kinda nice to put a hole in a side wall instead of a roof of what is being heated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2021 at 7:42pm
Gottcha, thanks for that - I do think water holds heat better than forced air heat , just looking for opinions on hot air
Edited by DougG - 04 Aug 2021 at 7:44pm
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2021 at 7:29pm
Folks at our local consignment auction have had 1 for years. They have several, looks like hanging furnaces in the shop and office area, they have fans blowing out air. But they are hooked into the outdoor furnace. It looks like some sorta fluid is pumped thru lines to these "registers". The first furnace they had blew hot air into the building.   This Is a former car dealership, large building. The heated fluid furnace is warmer than the forced air unit they previously had.
Edited by HD6GTOM - 04 Aug 2021 at 7:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2021 at 6:32pm
Anyone have an outside forced air wood furnace for a house ? I think Bryan is the prime name around here, just want some opinions on any , thanks
