CA engine rebuild for pulling
ACCA52 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACCA52 Quote  Post ReplyReply Direct Link To This Post Topic: CA engine rebuild for pulling
    Posted: 26 Jul 2021 at 6:24pm
I need to rebuild seized CA, what parts should I buy / work needs done to make a good pulling engine? i have not pulled the engine out of the tractor yet, but know it has been seized over 10 years and had water in the cylinders when I got it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 7:47pm
How much power do you want? What will you rules allow? What's your budget?
 I have a 170 CID engine that will make about 60 HP when the rules will allow it to run the way I pull them. Everything is to my own design as no one else does much beyond a stock overhaul for these engines. About 30 HP can be done without a lot of work and anything in between. There are some videos the have been posted by " Southern Maryland Maniacs" that show my tractors pulling.
  I'm in Maryland, just below Gettysburg and can help you with anything you'll need for a top notch CA puller. Send me a PM with your Email and I can see what I can do for you.
