D14 Final drive spacer |
bozrae
Bronze Level Joined: 02 Jul 2012 Location: Michigan Points: 160 |
Posted: 24 May 2021 at 5:41am |
Bought a D14 last fall and didn't notice until recently that it had spacers on the final drives. I looked this up in the online Agco Parts book and it does show them.
It says they are for 63" to 97" wheel tread. I've never seen these, does anyone know what implement they would be used for and how common are they? |
D15D, D17G, 170G, 175D, and two 5050FWA
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Here is a set I will be installing on a D-15 series 2 diesel along with a single front wheel for a forum member that I am rebuilding tractor for. ,he can jump in and fill u in on what he's doing it for.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 81278 |
Fred, is there an extension for the top shaft, or is it one complete DIFFERENT part from the standard D15 ?
Fred in Pa
Top shaft Is longer
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2766 |
I was also wondering about the pinion shaft . Thanks
bozrae
Were these used if you wanted a mounted corn picker?
Richardmo
Orange Level Access Joined: 12 Sep 2009 Location: Rolla mo. Points: 1744 |
They were used on the high crops D 14 and 15.
How wide are the spacers? Edited by Richardmo - 25 May 2021 at 10:30am |
bozrae
The spacers are 4-5/16" wide.
The reason I thought they might be for a mounted corn picker is because is has what looks to be a factor screen enclosure on the air intake.
Fred in Pa
6 1/2 on the axle's I am working on
mruhlig77
Orange Level Joined: 19 Aug 2014 Location: central Indiana Points: 578 |
In your AGCO book..do the spacers imply a high-crop or a single front end????I would bet on the corn picker or vegetables....Mark
Richardmo
The high crops have the wider one.
Also check the parts book calls out for a different axle for the picker so maybe that is what that is for. |
mruhlig77
Found my own D-15 book ....appears there were also 3 widths of wide front ends....did not list applications of the wider rear....Mark
bozrae
Here is some info from the online book. They have different part numbers for pinion shafts but only one part number for a RH and LH side spacer.
