D 15 pinion shaft lube
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 pinion shaft lube
    Posted: 09 May 2021 at 5:44pm
Is it ok to pack these bearings and the axle bearings with wheel bearing grease ? Am I right that they get oil that splashes off the oil tube after it comes off the bull gear ? THANKS !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 6:27pm
there is no need to put grease on the bearings... Everything inside is designed to be lubed by the splash system.... does not hurt to  squirt some oil on the bearings as you assemble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 6:50pm
Okay thanks Steve . I guess universal hydraulic/trans would be good ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 7:13pm
Some people use gear lube in the final drives, some use UTF..... Seems to work in 3-400 HP tractors so should be fine in a D15.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2021 at 7:21pm
Yeah I dropped the bull gear pans a year or so back and used UTF . THANKS !
