Used 8070 |
Page 12> |
PAFarmer
Joined: 06 Oct 2020 Location: Pennsylvania Points: 114 |
Topic: Used 8070Posted: 09 Mar 2021 at 2:59pm |
Hello Everyone,
I am looking at a used 8070 locally and was wondering if anyone would be willing to provide some pointers as to what to look for as far as problems are concerned. I spoke to the owners brother, and he knew very little about it. I crawled over the tractor some and didn't see anything mechanical that really stuck out. Cosmetically, it's roached. The interior is non existent and the paint is terribly faded. I don't know what year it is, the serial number sticker on the frame is very faded as it's been stored outdoors. Is there another way to figure that out? Some specs as I have them: - 8070 FWA with Power Shift transmission - Hour Meter reads 3300. I cannot imagine it's a 3000 hour tractor. So it's either wrapped around or doesn't work. - Oil pan is leaking around the block, I'd plan on a full out of frame anyways. - Large 1 3/4 1000 RPM PTO. Is it possible to install the 540/1000 swappable like the 8010 or similar? - Three SCVs. We own 5 ACs including an 8010 that has been a fantastic tractor. Next to no issues with it. Only minor things. A bit fuel thirsty and doesn't enjoy the cold starts so much albeit. So I'm hoping that this is just it's big brother. We're mostly no-till so it would mostly be a grain drill tractor and pull a 18' VT to clean up the occasional ruts in the wet spots. It would also probably run forage chopper some. Are the 8070s as good of a tractor as the 8010, or are they known problem children? And what are some common issues to look for? I figure I could convince the owner to let me work it in the field a bit even before purchase. Thanks! EDIT More info from the owner: Hour meter does work, so it's a 13k hour tractor! WOW It's a 1984 year model. Hasn't ran in 4 years. I'm gonna go try and bring it to life this weekend. But this one may be best left in the weeds. Edited by PAFarmer - 09 Mar 2021 at 3:57pm |
Ron(AB)
Posted: 09 Mar 2021 at 8:39pm |
If you have the money and the time...yes.
405, 7000, 7050, 8050, 8070, L3, 2300 & 2600 disk
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 314 |
Posted: 09 Mar 2021 at 10:41pm |
Yes you can put a 540/1000 rpm 2 speed pto on it. Will need a donor tractor for the parts.
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8989 |
Posted: 09 Mar 2021 at 11:53pm |
Serial # is stamped on rear rt above PTO. They are not trouble makers....but if not cared for,its like any other mechanical thing. From the description don't pay much. There are better ones for the same money.
PAFarmer
Posted: 10 Mar 2021 at 6:31am |
Thanks, all. Based on the fact that it would need a full cab off restoration and an out of frame overhaul, the price would have to be super attractive. The best thing it has going for it is the inside set of rear rubber only has around 50 hours on it.
I'm told they bought the tractor as a grain cart tractor and then promptly bought a bigger grain cart that was just too much for it, so it got parked. |
Transaxial
Joined: 19 Apr 2014 Location: Tofield,Alberta Points: 96 |
Posted: 10 Mar 2021 at 10:33am |
You just missed a good 8070 power shift MFWD! I have owned the tractor since 2003 and knew the PO who did some light loader work for 5 years. So in about 1998 he bought a one owner tractor with a new engine at 4500 hrs from a local dealer. It now has 6200 hrs and has been in the shed and well maintained since 2003. I did a complete paint job on it about 2017 and the interior is the original in pretty nice condition with the original checker board upholstery on the seat. I had very little trouble in the 18 years that I owned it. Fuel injection pump rebuild, batteries, rework the detent system in the power shift, fix leaks on engine is about all. The clutch was never set right so the inching function was not working resulting in very jerky clutch engagement. Dr Allis on this forum helped me zero in on what the problem was and I got that working well. I know the guy that bought mine and he wanted a good old school tractor to do some snow removal around the yard and run augers and his 5 year old tractor was giving him too much trouble throwing codes and derating so he is replacing it with this 38 year old one. He did a lot of research on these 7000 and 8000 series tractors and found that the power shift seemed to be a very reliable transmission. The rear end and hydraulics also seems to be pretty well bullet proof. Overall the 8070 he found has a very good reputation in this area. I think any time you buy the highest HP model of a tractor you stand some risk of over doing it but for most of these that are not doing the heavy work any more I think they are a pretty reliable and well built tractor. Parts seem to be available although there are not many of the old school mechanics left that could rebuild them with a blind fold on. I just got $30,000 for mine with a $7,500 Ezee-on loader and a 3 PT hitch. I tried to send a couple pictures but the file size is too big. If you want some pics PM me your email and I will send you some.
Transaxial
Posted: 10 Mar 2021 at 10:46am |
I forgot to add that the hydraulics have pretty high flow for a tractor of this age and a closed center system so for modern day loads this 8070 is no slouch. The old 426 cu in engine has been re labeled many times over the years as 3500, 3750, and in this tractor as a 670I I think. It is turbocharged and intercooled and rated at 170 pto hp IIRC. They dropped the hp and top rpm a little from the highest ratings in the 7080, 7580 and some combine engines and these seem to last longer in this configuration.
PAFarmer
Posted: 10 Mar 2021 at 10:47am |
I'm in the position with this 8070 that our operation doesn't absolutely need another tractor. But, it would be nice to have and I have a disease when it comes to Allis Chalmers tractors. Every time I see this poor 8070 sitting in the weeds, it calls out for me to rescue it. It would be lucky to see 200 hours a year to be honest, but they're such a nice looking tractor and it would relieve some of the work from our 8010. I'd love to keep the hours down on it as much as possible at this point. We shall see what happens. 13,000+ hours really is a lot!
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 10 Mar 2021 at 11:48am |
Why would u want 540 PTO on a 170 HP Tractor .
PAFarmer
Posted: 10 Mar 2021 at 11:54am |
Just in case. One never knows. If we were to have a smaller tractor broken down and I were to need it to run, say a small square baler or something along these lines. Wouldn't be a very common thing, but one never knows. It's not uncommon for us to have every tractor we own busy at the same time. Especially when hay making is in full swing. If one went down, it would be nice to have the option to use the 8070 on a hay rake, or baler or something. Drive lines will be fine on equipment that doesn't run hard like that.
Ron(AB)
Posted: 10 Mar 2021 at 1:11pm |
The big shaft pto is useless for most farms. I changed mine out asap when I purchased a 8070. I have used both the 540 and 1000 now... |
PAFarmer
Posted: 10 Mar 2021 at 2:27pm |
This is my experience. The big 1000 shaft is very much useless for me and we'd be running an adapter all the time even for our 1000 RPM implements. I don't really know if it was a different era thing, or what. But for example our forage harvester drive line is rated to 225 HP and it's the small 1000. I've always wondered about that. And it sure would be handy to have the 540 for augers or balers and such if need be.
What parts were required for the conversion, Ron? I've never been into the PTO on our 8010 so I don't really have a good understanding of the 540, 1000 part. I'd suspect it's just a planetary of some type. |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 10 Mar 2021 at 3:32pm |
My 8050 turns 164hp and runs a 540 discbine. 10 foot tall sorghum she barks. |
Transaxial
Posted: 10 Mar 2021 at 7:53pm |
Since 1973 we ran a 914 IH pull type combine on 1 3/8 1000 shaft on a IH 806 and later a 1206. In 1979 we bought a Versatile 500 that was 160 pto hp and had the big shaft. It ran with an adapter until 2004 when we bought a Versatile 2000 pull type that had the big 1000 shaft. In 1986 I bought a 8550 Allis with big 1000 shaft that ran on the Versatile combine until 2002. In 1989 I did a repower on the 8550 to a 350 Cummins so it needed the big 1000 rpm shaft. We have done lots of work with 1000 rpm pto on M & W grain dryers, water pumps, manure pumps (150 - 300 hp), Northwest 9 ft HD rototiller (150 - 350 hp), 13 x 85 augers. Lots of it with an adapter from big 1000 to small 1000. I still have a bunch of adapters to use a tractor with big 1000 down to 1 3/8" 540 on an auger to get the job done. If you are using a lot of power and doing a season of work it is best to just change the yoke on your implement to the big 1000 size. I have always had a reliable old IH 1206 with the dual shafts that was sure handy for the augers and smaller jobs. When I start listing off the uses for big power pto it starts to add up!
Ron(AB)
Thanks(1)
Posted: 10 Mar 2021 at 9:05pm |
Do a search on it. It comes up every 6 months. It is very easy to do. There are a lot of pics with the details of parts. You can get them at a wrecker. The biggest hassle is draining the oil... |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
13,000 Hours for a 35 year old tractor is not bad. It's not unusual to see 10 year old tractors with those hours now. My neighbor bought a 10 year old JD thinking it had 3,900 hours. When the engine spun a bearing the first time he used it, he did some digging and found out it actually had 13,900 hours. He rebuilt the engine and is still using it these days. Another thing to remember is that a lot of ACs had hour meters that died, or the drive cable broke OR the alternator got replaced with one that did not have the correct drive mechanism. I have 16 AC tractors and I think only 2 of them are showing actual hours! To me, hours mean nothing on these old tractors.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4875 |
Posted: 11 Mar 2021 at 12:39pm |
Yep very, very few tractors would I believe the hour meter on. And that is not from thinking
someone has been up to funny business. I just know how much effort I have put into having a hour meter on a working tractor, and still don't.
HagerAC
Thanks(1)
Posted: 12 Mar 2021 at 7:30am |
Check the front driveshaft yoke on the front axle where it slides onto the pinion shaft. It's most likely sloppy. Get a new yoke from agco and cut off about 3/4 of an inch off of the old yoke and weld on the front of the new yoke. Makes a world of difference. I just did mine last week. New yoke is close to $600. Just something else to consider in your purchase price.
PAFarmer
Posted: 12 Mar 2021 at 8:04am |
Good advice! Thanks. Do you have a picture of your modified yoke, Hager?
Gregor
Joined: 11 Sep 2009 Location: Prague, Ne Points: 305 |
Posted: 12 Mar 2021 at 8:31am |
My loader tractor is a FWA 8070. I put on about 20 hrs a year on it. My father bought it in the late 80's and it's pretty much mine now. Put a loader on it when we went to no-till and the tractor not needed much. Think I have around 6200 hrs on it. It's been a great tractor. I overhauled a couple years ago. My cold starts good. Most of the time I have in the shed, but the other day, it popped off at about 30 degrees outside. I have never used the PTO. I agree, switch out to the smaller diameter one. I have an adapter for it, but most of my stuff has 540. Only problem I have is it loses prime after sitting a day and hard to start. I changed every seal on the fuel lines and overhauled the pump and that didn't help. I put an electric lift pump on the frame and that fixed my problem. You'd think I'd find a fuel leak, but haven't yet. For the oil pan gasket, when I overhauled it, I used what it came with in the kit and didn't like it. I should have found something better. It comes in several pieces and fought it the whole way. Need to find a 1 piece gasket and redo as that is my only leak.
randy
Joined: 12 Sep 2009 Location: Illinois Points: 1260 |
Posted: 12 Mar 2021 at 8:46am |
My 8050 had a , air leak, not a fuel leak and would loose prime. Check the return hose in the fuel tank. They sometimes fall off due to old age! When the hose falls off it lost its prime after a few days. take the cap off the fuel tand and look in there.
PAFarmer
Posted: 12 Mar 2021 at 9:33am |
My Uncle has an 8050 2WD and it had the same problem with the loss of prime. It was an air leak, that much I remember. I don't remember where the issue ended up being. Guess that's a difference between the 301 and the 426. Our 8010 has an electric pump. |
Gregor
Thanks, I will look. This used to take a couple days to lose its prime and got worse and takes about 8 hrs or so now. I agree it is an air leak. This one has me stumped. I was thinking about changing the hose from the tank to the water filter as I have the electric pump primed in after the water filter on the left side and that hose looks rough. Only problem with the electric pump I have is it is wired to turn on with the key on and when i crank, it quits. If cranking for 7-8 seconds when really cold out and not plugged it, I have to stop and let the pump run. Need to wire it to a switch. I took the pump from a junked out N6 that I had replaced the pump right before we junked out the combine. Fittings were the same and used one of the hoses off the combine. Worked pretty slick. I was thinking once I put positive pressure on the system, I'd find the air leak with a line or fitting that would get wet with fuel. Friend of mine had a hair line crack in one of the lines that never leaked fuel, but he did the same and it started a leak when he pressurized it like I'm doing. So far no leak. So look in there with a flash light and you see the hose laying in the bottom of the tank??? IF so how did you put it back on? Otherwise pump fixed my starting problem. Just turn the key on, wait 5 seconds and she pops right off.
randy
Posted: 12 Mar 2021 at 9:53am |
On top of the tank the return line from the pump goes on a fitting. I used a long screwdriver to move around in the tank to feel if the hose was there. If you have to replace the hose, drop the tank a little bit and wiggle the fitting to get it out. Mine has at least one hose dropped in the bottom of the tank!
PAFarmer
Posted: 12 Mar 2021 at 9:56am |
Has anyone here done a resto of an 8000 series lately? What paint are you using? We are going to have to repaint our 8010 this winter and if I buy this 8070, it needs a full resto. I'd like to clear coat for a nice shine, and recommendations?
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 12 Mar 2021 at 4:47pm |
Well now, I never thought of that. My splines are shot on the pinion shaft and I was told no dice for parts, was your splines wore badly? I have the new yoke and pulled the drive shaft on my 8070 but haven't put it back together, because of the splines on the pinion shaft. I was thinking of trying to drill a hole back so the yoke would slide up further to get all good splines that weren't wore. Maybe I should go your route instead.
PAFarmer
Posted: 12 Mar 2021 at 6:46pm |
Sorry for being thick headed, I just want to make sure I understand. You're lengthening the splined part of the pinion yoke by welding a piece of the old yoke onto the new yoke?
Kansas99
Posted: 12 Mar 2021 at 7:20pm |
No I think he is saying welding a piece of the old yoke to the new yoke so it is longer and reaches further ahead on the pinion shaft to grab more splines that are good. I'm sure Dr. Allis is shaking his head right now.
HagerAC
Posted: 12 Mar 2021 at 9:26pm |
This is a pretty common fix that I've read on here many times and my dad has done this on my uncle's 8010 as well. Yes, i slid the old yoke on as far as I could and measured the difference from where it was. Then i cut off that much from the old yoke and welded to the front of the new yoke. It was like .7 of an inch so not quite 3/4. That gives you max amount of spline coverage. The front yoke was a poor design on these, especially when there is more spline on the pinion shaft that isn't even used. I can try to get a pic of it tomorrow. I was gonna take pics while i did it but we all know how that goes.
HagerAC
Posted: 13 Mar 2021 at 8:50pm |
Page 12> |
