Log carry?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: Log carry?
    Posted: 24 Feb 2021 at 6:27am
anyone have one they want to sell? I've seen these used/pictures shown of using but never for sale?
Even an old axle with good tires would work as I can weld up the u shaped cradle to go onto...
Pm me please, thanks fellas!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 8:19am
how about an old trailer... trailer axle... rear axle from 1/2 ton truck..
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 8:26am
I think littlemarv made one. Maybe he would chime in?
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 11:18am
I'm not sure how much weight they will carry, but a rear axle off of a front wheel drive car is clean straight axle.   Depending on how big the log is, I've put a chain around a log and around a blade or drawbar on the three point and got the end off the ground.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 11:31am
A true log arch has no straight axle between the wheels....the wheels are attached at each end of the arch itself. The straight axle would be in the way.
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 11:57am
Check Northern Tool.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 1:05pm
Do it yourself log carrier.
https://m.youtube.com/watch?v=qzbL8mhPi2U
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 4:22pm
AKA as a swing cart a lot of places.Make one out of an old fertilizer tank carrier and get a couple 12V winches to lift the logs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 5:30pm
The one I made, I used the bottom frame from a 300 gallon sprayer, put 20" bus tires on it.  I made a sloping piece of 1" diameter stock, from the front tongue up and over the frame. Used a sliding clevis on the round stock, to lift the log, as you pull forward. that way, you back into the log, hook chain up to the front of the log, as tight as you can, jerk forward, and the log lifts itself up, on the front end!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 9:34pm
i use an old propane tank carrier, it's open between the 2 wheels and the top is strong, i used a 12V winch to do the lifting, can tow behind a tractor or pickup.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2021 at 9:58pm
Oh boy, here you go. My adventures in logging thus far....
Personally can't wait for this spring to try out everything I've been scheming on this winter.
The mechanic always wins.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2021 at 6:58am
To obtain an old Axle for cheap, visit an RV Repair Shop and get an "slightly out of alignment' RV Axle, the result of hitting a Pot Hole.
G
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2021 at 9:40am
Quote; littlemarv
I'm with you 100% on that! Stupid snow and sub zero temps. have been a drag. Several more trees that need felled.....
Edited by IBWD MIke - 25 Feb 2021 at 9:41am
