Steering problems. Fiat Allis 545B |
GHamm
Joined: 24 Jan 2021 Location: Ontario, Canada Points: 2 |
Topic: Steering problems. Fiat Allis 545BPosted: 24 Jan 2021 at 9:26am |
When going straight ahead it steers good. When backing up it has a mind of its own, going either left or right. You can’t control it with the steering wheel. Gets worse the longer it run.
Any ideas
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42262 |
Posted: 25 Jan 2021 at 10:18pm |
Sounds like the cylinders might have internal leakage creating hydraulic cylinder voids in fluid . Could be the cylinders themselves or the steering box leakage .
Reminds me of my old straight frame Pettybone - going forward to load bucket as low speed was fine - backing up it would not track in same position as forward . But if you roaded it you had to go in revers or it wandered everywhere and was next to impossible to go in a straight line . My 715B TLB has hydraulic steering and when on the road you need to keep steering to correct straight travel - and when you check the steering wheel position it has made a complete revolution or more from when you started driving - slow hydraulic leaking and as is a hydraulic valve it has no mechanical stop or home center position , Yet at low speed you can lock wheels in any position of steer and load pump pressure to cylinder on tie rod |
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8978 |
Posted: 30 Jan 2021 at 11:34am |
Can't answer that but they do have an interesting system. Steering gear with drag link to physically steer it but also used hyd steering valve to operate steering cylinders.
