AC subsoiler |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Nov 2020 at 7:04pm |
I'm wanting a snap-couple subsoiler for my D17. My question is are they model specific?? Other words would one from a CA fit a D17??? Thanks in advance Keith so. va.
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4051 |
Any of the snap-couple sub-soilers you find will fit your D-17. There was a No. 3, a No. 4, and the curved shank Oxnard model. Also a model 44 twin shank model, (I have never seen one). Hard as one shank pulls around here I think a 17 would struggle mightily with two!
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5061 |
The attachments for the CA as well as the D10/12 tractors will not work with a D17 unless you do a bit of modification, the length is shorter. Also the larger D-series tractor need to have the eye curved upward or the hitch will interfere with the bottom of the transmission/rear housing unless the lift links are long enough.
OK thats two different opinions from two well respected members here. Anyone else want to chime in???
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53966 |
I'll second what Paul said...
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3062 |
Agree with Paul and Dave the tongue is shorter on the CA,D10/12.Also I have a subsoiler that came with a WD had to notch the tongue out to use it on my D15 so it wouldn't jam up against the housing.Think I remember that the PTO shaft on the WD had to be removed to use it.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24595 |
I'm thinking I have the 'curved Oxnard' subsoiler. Kinda looks like a '?' on it's side, with reversible 'point'. Whatever it is, it works real good behind my D-14 !! Now that shop is sold, wife says sell it....heck, she says sell ALL the 'tractor stuff'....
My comment is based on the fact that I have never seen, (in person or Norm's book) a sub-soiler for a CA, D-10, 12. Edit; Looked at the 'Bible' again. It does say the no. 3&4 were available for the CA. Does not say anything about different length draw-bars.
Edited by IBWD MIke - 14 Nov 2020 at 6:13am |
