Wood for idler blocks
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: Wood for idler blocks
    Posted: 19 Oct 2020 at 6:20am
Finished filling crib this weekend. Started putting picker away and I noticed the wooden idler blocks are the elevator drive chains are done and I am sure they are nla. What wood do you think I should use to fabricate new ones?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 6:28am
I have plenty of available Osage Orange, commonly know as Hedge, that would work for a LONG time. Any kind of Oak would do, or maybe Ash. Some Ash is much finer grain than others. The finer the grain, the longer it will last IMO.
 A few years back, I had a bearing out of my 6 foot 3 point disc. I was thinking of using hedge, but had a mulberry branch by my deer stand that seemed to be about the right size, so I made the new bearing out of mulberry. Probably not the best wood for a bearing, but it will last as long as I need it to.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 6:50am
Did you soak it in oil before using, or did you install it dry.
I have a project I'm building that I'm considering using pieces of 3" x 4" oak blocks for the bearings on 1 1/4" shaft.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:09am
Hedge, oak, other hard wood, cut in shape of a half moon key, soak in oil.
Also wood bearings in the old MM disk, had a pair and that hung in the shop for the pattern.
A rotary hoe I had had wood block halves for bearings
Edited by JoeO(CMO) - 19 Oct 2020 at 7:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:13am
Years ago, the Gleaner wood blocks practically dripped oil on the parts room shelves. Some batches were oilier than others.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:16am
I've been making idlers out of high density plastic. (the white stuff) Seems to work good and last a long time. Darrel
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:45am
Lots of wood bearings still available for red combines. Some for the grain elevators might even work for you, with or without minor mods.
I think they are made out of some sort of hard maple, oil impregnated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:59am
epay (sp?) some SA hardwood, tougher than nails( yeah you MUST predrill holes !!!). some use for decking...
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:17pm
Found a scrap of white oak, got a neighbor to cut it on his band saw and it is soaking in oil as we speak. Never heard it called a hedge tree before. Here in politically correct New York we use to call them monkey ball trees, but I wouldn't say that out loud any more.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:18pm
Thank for the advice
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 7:58pm
Believe it or not but you could also try sycamore. When dry it is tougher than oak.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 9:01pm
When I redid an all crop 90 with a corn head I used white oak. A small table band saw and some drill bits and your done! Only thing I didn’t do was soak them in oil. Was in a hurry trying to get the project done. But the chains get oiled heavy anyway.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 12:45am
When we rebuilt an old case ground driven manure spreader wer used white oak had lots of it on the farm. Soaked over night in hot used oil before installing. They held up for 20 years when it was sold they still looked in good shape.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 2:16am
And Sycamore has no real grain,if you try to split a piece its very tough to do, dogwood is also very hard wood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 4:34am
Rock Maple is another, build miter boxes of it as harder than times in 1929.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 5:48am
My dad and grandfather always used hickory.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 6:54am
Find someone's firewood pile and ask for a piece of oak and make your blocks. If you don't have the tools to make them for the cost of shipping I will if if you email a sketch with dimensions.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 7:03am
I agree, Oak or Ash are common enough and should do a good job, I know someone mentioned Osage Orange, that is a really hard wood and used to be used as the pin in post frame buildings.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 7:53am
I remember pulling them out of the parts bins at Dad's dealership.  Some would almost drip oil they were so soaked.  Seems like sometimes they came in bags that would be oil-soaked.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 10:02am
Oil soaked oak seems to run forever.  My dad's F3 has white plastic blocks on it.  Seem to work very good as well.  Did Gleaner change over to the plastic or did someone add these?
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 10:20am
I’ve used dogwood for mandrel bearings and worked fine.
Edited by sparky - 20 Oct 2020 at 10:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 7:46am
 I did not soak it in oil. I made the bore about .030 bigger than the shaft, and cut a groove from the grease zerk, out both ways, to within a half inch of the end of the bearing.
 Put it together and pumped it full of grease.
 I'll never wear it out in 20 years of use. I only use it for a couple gardens and a couple acres of food plots.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 2:47pm
My '81 L2 has all plastic block idlers too. I figured someone added them. There's hardly a chain on the R52..... I think just the reverser and the unloader drive.... I know the unloader drive has an idler sprocket.
Edited by Lonn - 21 Oct 2020 at 2:48pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 10:24pm
i've always replaced them with the small steel idler pulleys with the 1/2 inch lip on each side. same size holes.
This page was generated in 0.067 seconds.
