AC 8050 clutch malfunction recap
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Topic: AC 8050 clutch malfunction recap
    Posted: 18 Aug 2020 at 1:39am
So this is what made my Allis's clutch not work. It broke some how and made the clutch inching spool not travel where it should for the clutch to disingage.
Can anyone tell me what the function of this stainless steel sheet metal fork is, why it ended up broken and how I could prevent it from happening again?
Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2020 at 5:33am
They do that over time. I suppose the more the clutch pedal is used, the sooner it does it, like maybe a tractor that runs a round baler. You are not the first. It probably won't happen again for another 35 yrs.
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2020 at 1:25am
thanks for the reply
glad to hear it wont happen again soon.
its going to be tricky for me to get that part in/to South Africa, so would it be possible maybe to make it myself? i would definitely need precise dimensions if i would try it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2020 at 10:06am
Well, you'll surely need the 2 valve body gaskets and the inching spool seal and the shift lever shaft seal. What are you going to do about those ??
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2020 at 6:25am
How many hours are on your 8050?
rieg
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 6:47am
the gaskets ill have to make myself, using high pressure paper.
the 2 seals was still good beforehand and i will have to hope it'll stay that way for now.
i managed to get the dimensions i need. doc, what i do need to know is whether this fork fits snug into the valve housing groove, because it seems that way? (the 2 bents on the sides seems to make it fit snug?)
Rieg: hours?  27916
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 8:11am
It just drops in the slot. The little handle sees that it is positioned correctly. I've been known to do things the hard way, but I cannot imagine making those two gaskets. Can't I simply UPS or mail you these parts ?? They would easily fit in a manila envelope.
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 12:49am
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 1:10am
Doc, if it don't work, I'm going to call you up on that offer!
Most companies won't ship to South Africa , so I stopped trying!
so it would help me allot if someone would go through the trouble of receiving and shipping parts like this, for me?
How obtainable are Allis part still in the USA?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 6:30am
I can have most AC parts overnite.  Some parts are no longer available, and then we improvise.
Zmf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zmf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2020 at 2:32pm
Hi doc.
Sorry for my late reply,but I'm so busy driving my Allis with all its improvised parts!
So far everything works just fine. Now I'll have to see how long everything will last.
While I was in the gearbox, I saw one gear-plate have wear on the spline teeth, so sometime in the future I will need to import some from the USA.So glad to hear that most parts are still out there. Thanks for your time, sir. Much appreciated
This page was generated in 0.065 seconds.
