Allis chalmers 715c hydraulic pump
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Topic: Allis chalmers 715c hydraulic pump
    Posted: 26 Aug 2020 at 2:44pm
Can you still get a hydraulic pump for the allis chalmers 715c backhoe with the allis chalmers 433t motor? Or will my best bet be my hydraulic shop for a rebuild. I think its a Cessna pump.
Edited by ac89 - 26 Aug 2020 at 2:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 3:13pm
Hydraulic shop will be your best bet, if need a Eaton Cessna they tend to still be available just have to match specs and drive spline.
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2020 at 3:27pm
That's what Im thinking. It'll be a good project for this winter.
Edited by ac89 - 26 Aug 2020 at 4:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2020 at 12:32pm
I had a Cessna pump on a New Holland skid steer that went bad was over $1,000 from dealer - hyd shop had a new pump for $300 but input shaft was different as NH had a propitiatory design - thing is old shaft was good and fit right into new pump - did the exchange of shaft in the price .
  Check with a shop or with MINNPAR to see if they have it in stock but be ready for $$$. Can try Surplus Center to see what they have that might exchange also as they can match many units  for pumps and cylinders
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2020 at 3:50pm
Ok I will have to look into that thanks
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 2:59pm
I found a pump online that is identical on the outside of mine. But it doesn't tell me the specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 3:09pm
Almost looks like the trans pump for my 7G
Can go to Eaton Cessna and look up by pump number for specs.
Edited by DMiller - 31 Aug 2020 at 3:10pm
ac89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac89 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 3:16pm
I'll try that thanks
markjlemmon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markjlemmon Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 3:40am
Hi, This is Mark.
A 715c hydraulic pump can handle fluids that are too viscous for a centrifugal pump. The pumping action is very controllable and mathematical. if you double the speed, you double the output.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 2:17pm
This page was generated in 0.081 seconds.
