Restored AC 7000 Maroon Belly
Maroon belly View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Topic: Restored AC 7000 Maroon Belly
    Posted: 30 Aug 2020 at 11:19pm
Iuploads/20613/1E4C3347-7454-4644-BADB-639B30E53BE1.jpeguploads/20613/10856E22-1187-45B8-A74C-BAE75CA6D262.jpeg
This has been my 6 month Covid project. This is a one owner tractor. The hood and grill are original paint. Black belly upholstery kit in the cab.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 12:29am
Awesome job ,looks great. Credit to you.👍👍
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 5:41am
VERY nice!
T-bone_indy View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote T-bone_indy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 5:46am
Now that's one nice tractor! looks great
D19-AC916-Kubota B2150- Wheel Horse charger 12
Kansas99 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Kansas99 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 7:20am
That the best thing I've seen come out of the covid bs.  Very nice!! Thumbs Up
allisorange View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 7:24am
Very nice Tractor. Excellent job.
    J. Carlson
Tim NH View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 9:54am
You did a nice job. I see you have a custom gas strut and bracket for opening the door. What did you use for the maroon paint.
  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 12:20pm
the door kit is from tomNE. It’s supposed to be mounted at top of door, but I didn’t like how it torqued the door, so I moved it mid door. The bracket I made to get the strut to work better. The paint used was ac Persian and ac maroon in rattle cans and lots of wet sanding before and between coats. The front axle was exchanged off our 7010 for loader work. The additional frame was the quick mount for the farmhand loader now used on my jd 7700. It benefited the tractor by eliminating the twisting that caused oil leaks. There is around 7400 hrs on the tractor. It had an preventive underhaul at 5000hrs. I appreciate all the kind comments.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 12:52pm
Totally cool.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 8:31pm
Wow telling us the hours makes the paint even more impressive.
Vary nice
JohnColo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 11:14pm
That is a nice looking tractor you have there!
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2020 at 11:40pm
Great idea on fitting the door kit. sometimes there are better ways of attaching parts.
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 7:26pm
Thumbs Up
If fishing is a sport your looking at an athlete
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 8:16pm
Whew! That's nicer than when it was brandy new! Great job! To nice to get dirty....
Steve@B&B
Acdiesel View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 8:39pm
Clap looks good!
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
LionelinKY View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 2:20am
AWESOME job!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 8:56am
I think painting the front hub, wheel and lug bolts all the same color is tacky, but I tried to stay true to original.  If you see something wrong, please point it out.
Side note, I submitted this photo to orschelns 2021 calendar contest for antique and restored tractors. I figure anything over 35 yrs qualifies.
Hurst View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 7:41pm
Looks great!  When you say oil leaks from twisting, is that from the front cover and engine plate area?  I'd be interested in seeing a close up of how it reinforces the frame rails because mine leaks there again after all new gaskets and seals on the front plate several years back (along with a patched oil pan where it cracked from the flexing).
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 8:27pm
I’ll get some pics tomorrow.
AC7060IL View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 8:42pm
Matron Belly, That’s a great looking AC 7000! The maroon paint is a nice throwback to its AC era.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 7:40am
I don't want to sound critical because you've done a beautiful job!  The only thing I see not original is the rear axles should be black versus cream.  The front hubs look fine to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 8:27am
That is a possibility, as the color pic on the manual cover is long gone, so going off black and white pics. I appreciate constructive criticism.
Dave in il View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 9:55am
It's a matter of opinion, other than shiny new lug nuts that's the way that the front wheel looked from the factory. I think if the hubs were burgundy (or orange on older models) it looks tacky, like the painter was too lazy the finish the job. Remember your tractor my opinion, tractor owner wins lol.
That said you did a heck of a job and have an outstanding tractor
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 12:44pm
You don’t think the lug nuts were painted?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 12:52pm
You have it right,front hubs and bolts should be cream. The rear axle should also be cream on that series. Looks really good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 4:44pm
[QUOTE=Hurst]Looks great!  When you say oil leaks from twisting, is that from the front cover and engine plate area?  I'd be interested in seeing a close up of how it reinforces the frame rails because mine leaks there again after all new gaskets and seals on the front plate several years back (along with a patched oil pan where it cracked from the flexing).
Hurst
[/QUOTE
The reinforcement runs from the back axle (first pic) to the front of tractor to weight bracket (second pic). My loader mount takes place of weight bracket, but essentially same thing. Last pic shows center portion of framework.
Edited by Maroon belly - 03 Sep 2020 at 4:47pm
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 4:48pm
According to my sales brochure on the "7000" tractor (Which is in pristine condition & in color) your paint is 100% correct in every aspect. If you have any interest in the brochure send me a "PM" with an address and I will send it to you. Your tractor looks GREAT !!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 5:22pm
I've had 3 7060s and a 7080 none of the lug nuts were painted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 5:25pm
I assume the hubs and rims were painted before they got to the assembly line
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maroon belly Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2020 at 5:54pm
I thought I would add some pics of interior and rear end. uploads/20613/62BB52E6-743F-406A-AFCC-F0C341876E95.jpeg
This page was generated in 0.083 seconds.
