Allis Chalmers WD45 Diesel project |
Page 123 8> |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 908 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Jul 2020 at 10:16am |
Hi to all, just got me a nice WD45 with a D19 diesel repower engine in it. It has been setting for about 20 years in a machinery shed. Put new diesel in it and it started right up.
Got it to a shop so I can work on it and so far I took it in to get rid of the fluid in the rear tires and change the oil. Would post a picture but it won’t load. |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4035 |
Good luck with the tractor and welcome to the forum.
Got to looking at it and the radiator and the diesel pump are leaking.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7484 |
Welcome to the world of buying old tractors. Not trying to bring you down but you WILL find more things wrong with it the more you look. Deal with them when you stumble across them.
Yes I know that from experience!!
Does anyone know how hard it is to take apart and put together those pumps are? |
These pumps are NOT for an amateur! Send it to a shop that knows these pumps.
My cousin might be able to help on the pump so I might be in good luck. I got the tractor from him.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8449 |
55allis,
Welcome! Glad the tractor is running. As mentioned they tend to mark there territory. Every thing about a diesel is a little more complicated than a gas job. But you have a rare tractor. Under 7000 made I believe. You might need to reduce the picture size to around 800 x 600 pixels for it to load better. Regards, Chris |
Ok thanks
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8310 |
Good looking tractor
How thick is a late d17 diesel head gasket?
.065. MACK
Ok thanks Mack.
![]() Thanks!! |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34283 |
Have you physically checked to see by rotating engine and then checking the valve for movement at tdc of engine with the valve open?
When my cousin overhauled it 30 some years ago he put d17 pistons in it and so he drove it 10 miles right after he overhauled it and it bent a few pushrods, so he was in a hurry to use it and retarded the camshaft and fixed all the pushrods it bent
Now if that explains what happened |
Don't think there is a thicker head gasket + that would increase the chances of blowing head gasket. MACK
Machine some from top of pistons. MACK
I think it will be fine with a d17 head gasket besides they are a bit thicker.
All 230-262 diesel head gaskets are the same thickness. MACK
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
There must be a difference in cams for the D17 pistons to hit in a D19 diesel. The later D19 compression ratio is 15:1 and the D17 is 15.7:1. Machining pistons would fix it. Of course I have little experience in those engines........ Looking at the parts page it looks like the cam changed and when using the new cam you had to change to newer pistons. I'm just babbling for my own edjamacation.
Wink I am a Russian Bot |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8573 |
Do the diesels have flat surface where valve sets requiring specific stand out? Someone put seats in my 8070 before I got it and didn't set them down...had valve marks in carbon on 4 pistons.
I believe they are flat
55 allis,
I can see you have some experience in these engines and that's good. I do not. A good friend and good mechanic on these 45D engines gave me advice on them. If you want to chat P.M. me. Thanks for posting the picture of your tractor! Regards, Chris
Albert ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: NW MO Points: 410 |
The AGCO head gaskets had a sheet of paper inside them on the piston machining needed. AGCO has killed the head gasket but Tony at Tony's tractor has one left of the AGCO gaskets left'
Albert |
Ok but already got one coming
Thanks |
Got the one rim and tire put together and painted [IMG]http://
![]() Here is the picture, it didn’t work the first time |
![]() Here is a better picture |
55, that looks great!
Nice big 16.9's on the 45D! I like it. Wheel looks good!
Thanks for posting. Regards, Chris
Page 123 8> |
