F2 Traction Belt? |
FREEDGUY
Topic: F2 Traction Belt?Posted: 15 Aug 2020 at 4:59pm |
I was out at the farm today to "fire up" the equipment. I started looking at the traction belt that goes from the main counter shaft, over the "idler" pulley and down to the tranny input . OMG, if that belt needs replacing, how does it get "squirreled" onto the tranny pulley with the brake mechanism within an 1"of that brake assembly ??
MACK
Posted: 15 Aug 2020 at 9:00pm |
It will go, just takes so effort to squeeze it through. MACK
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8985 |
Posted: 16 Aug 2020 at 1:21pm |
Like MACK says...you haven't ask the important question about getting it off the pulleys.....
DougG
Posted: 16 Aug 2020 at 2:35pm |
Its a - WHAT WERE THEY THINKING - deal,,
FREEDGUY
Posted: 16 Aug 2020 at 4:45pm |
Luckily it's not a needed repair, I just happened to look down and noticed how close the pulley was to the brake "tower"
. In hind site, I think the variable speed is in the "upper" end of the speed range, so I "assume" that in a slower range, the pulley will bet a little farther away ![]() ?? Thanks guys
MACK
Posted: 16 Aug 2020 at 9:20pm |
No, outer stays same place, inner moves. MACK
FREEDGUY
Posted: 17 Aug 2020 at 5:26pm |
Mack, I wondered about which sheave moved on the "bottom end"
I just can't imagine "jamming/contorting" a brand new belt between the outer sheave and that brake tower . Thanks for the reply . Any idea of how much hydraulic fluid, if any, would be lost when disconnecting the "upper" end of the drive system to get the belt over THAT pulley ?? Sadly, I'm the one that has greased the 2 fittings on the lower end for the past 12 years and NEVER noticed the clearance until this past weekend ![]() ![]() Edited by FREEDGUY - 17 Aug 2020 at 5:29pm |
MACK
Posted: 17 Aug 2020 at 8:51pm |
Fluid loss is a small amount. MACK
