D 15 front axle bushing
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 front axle bushing
    Posted: 07 Aug 2020 at 11:09am
Anyone have any tips on removing this old pivot pin support bushing ? It's p/n #70233368 if that helps . Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 11:20am
If it is steel, weld a bolt to it to pull it out. Tracy
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 11:33am
IIRC, the bushings are some alloy of bronze or similar.
Used a "bushing splitter" on my D17
A bushing splitter is nothing more than a narrow chisel with an acute angled point., and almost square.
They work great for just this kind of bushing in a blind hole.
Edited by Gatz in NE - 07 Aug 2020 at 11:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 12:01pm
It's steel . May have to separate this piece from the steering box and see if I can find a friendly machine shop ? Don't have any welding skills . Thanks !!
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 4:03pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 9:10pm
I had to split the one on my 170 with a torch to get it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 6:17am
Yeah Joe . Sounds like the smart way to do it . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 7:43am
really  ? a ROUND hole ?? THAT'S what it's supposed to look like ? NOT egged shape....
sigh.....
I'm guessin you put mor ehtna 12 hrs a year in the D15 seat.....
since I sold next door ,I've put 15 minutes warmin my tookuson Troy.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 8:42am
I dunno Jay . Prolly only get 5 - 6 hours of seat time a year . I just kinda enjoy fixing things on this old tractor . Mostly anyway . Thanks !
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 8:43am
Hope this isn't a silly question.  What is the purpose of this pin?  Mine has a grease zerk at the end of it.  If one  keeps it greased, in theory it should last forever.  Correct?  Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2020 at 7:21pm
Grease certainly would seem to help in my opinion . Maybe the pivot pin is there so the axle can move when you drive one wheel in a hole ? Maybe someone else knows ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 8:04am
I wonder if building up this pin with JB Weld would hold up ? Might just be a waste of time and JB Weld ? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 8:06am
waste of time... I don't think JBWeld would survive the shock of a few 'gopher hole' events.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 8:11am
Not JB....just weld it up and dress it down with a angle grinder. Don't have to be perfect. Fiddle with it till bushing slips over it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 8:24am
Thanks Jay and Steve . Kinda what I thought too .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 8:40am
Pay attention to where to grease hole is and drill out when done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 9:57am
I could be wrong , but don't think there is a grease fitting hole ? Plan to slap some grease on the pin when I put it back together . Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 8:17am
Think you're right about pin...isn't there a zerk in housing?
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 9:30am
Cram a piece of loaf bread in the old bushing and take a piece of shaft 1 1/4" and drive the bread in it and it should push the bushing out. Is this bushing available from Agco? I need one for my 170.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2020 at 9:40pm
If it's steel, I like to run a bead (or 2x 180 degrees apart) with the welder.  It needs to be hot enough it will heat all the way through, but don't want to burn through.  If you do that, the heat of the weld expands the bushing, and as you're welding it, it creates a soft spot for the expanded bushing to squeeze together.  When it cools off (let it cool off on it's own, not rapidly with water), the bushing should be nice and loose and come right out.  Putting them back in, throw them in a freezer and take a propane torch to heat up the opening just before you go to put it in and it should drop back in.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2020 at 12:03pm
As you can tell from the pics I kept after my old bushing with a hammer and chisel until it finally shattered . Prolly should've done like Hurst suggested but I just tapped the new one in . Good luck !
This page was generated in 0.168 seconds.
