d-17 chain down lift arms ???
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d-17 chain down lift arms ???
    Posted: 26 Jul 2020 at 3:07am
I got my new-to-me NH 472 haybine hooked up yesterday, gonna use the d-17 [series 1],  only 1 remote.  I put a vent plug in the return port of cylinder.  Seems I remember reading about chaining down the lift arms so as not to have a delay when wanting to raise the haybine.  Anyone do this, & is there anything to watch for ??   Thanks in advance keith so. va.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 5:15am
I wouldn't chain them down, just drop the haybine, then move the lift lever to the hold position, and they'll stay up...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 6:04am
If they settle down on their own, tie them UP to the back of the seat frame so they stay up all the time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:27am
Chaining down could really do some damage!  Chaining up is a far better choice.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 9:49am
If you chain it down, every time you move the lever to the raise position you are putting a lot of pressure on the hydraulic hoses, lift cylinders,  lift arms, rock shaft and whatever you chain to.
Remember that the Series 1 is the old high pressure hydraulic system.
Edited by WF owner - 26 Jul 2020 at 9:50am
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 10:51am
Chain,wire,tie them UP   Did it for years and it works perfect. If you don't secure them up they may slowly drift down. The haybine needs to float so make sure the lift/lower lever is all the way down when mowing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2020 at 6:07pm
ok I'll chain them up, thanks !!!!!
