Allis Chalmers WD45 Diesel project
 Post Reply Post Reply Page  123 8>
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers WD45 Diesel project
    Posted: 01 Jul 2020 at 10:16am
Hi to all, just got me a nice WD45 with a D19 diesel repower engine in it. It has been setting for about 20 years in a machinery shed. Put new diesel in it and it started right up.
Got it to a shop so I can work on it and so far I took it in to get rid of the fluid in the rear tires and change the oil.
Would post a picture but it won’t load.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2020 at 12:35pm
Good luck with the tractor and welcome to the forum.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2020 at 5:57pm
Got to looking at it and the radiator and the diesel pump are leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2020 at 9:02pm
Welcome to the world of buying old tractors.  Not trying to bring you down but you WILL find more things wrong with it the more you look.  Deal with them when you stumble across them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2020 at 9:12pm
Yes I know that from experience!!
Does anyone know how hard it is to take apart and put together those pumps are?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2020 at 9:45pm
These pumps are NOT for an amateur!  Send it to a shop that knows these pumps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 1:01pm
My cousin might be able to help on the pump so I might be in good luck. I got the tractor from him.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2020 at 3:04pm
55allis,
 Welcome! Glad the tractor is running. As mentioned they tend to mark there territory.
Every thing about a diesel is a little more complicated than a gas job. But you have a rare tractor. Under 7000 made I believe.
You might need to reduce the picture size to around 800 x 600 pixels for it to load better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2020 at 10:57pm
Ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2020 at 10:37am
Good looking tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 6:37pm
How thick is a late d17 diesel head gasket?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 9:09pm
.065.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2020 at 10:06pm
Ok thanks Mack. it has d17 pistons and the valves hit the pistons so I think a thicker head gasket will fix that problem.
            Thanks!!
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 8:15am
Have you physically checked to see by rotating engine and then checking the valve for  movement at tdc of engine with the valve open?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 11:30am
When my cousin overhauled it 30 some years ago he put d17 pistons in it and so he drove it 10 miles right after he overhauled it and it bent a few pushrods, so he was in a hurry to use it and retarded the camshaft and fixed all the pushrods it bent
Now if that explains what happened
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 8:53pm
Don't think there is a thicker head gasket + that would increase the chances of blowing head gasket.            MACK
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 8:55pm
Machine some from top of pistons.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2020 at 9:23pm
I think it will be fine with a d17 head gasket besides they are a bit thicker.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2020 at 6:49am
All 230-262 diesel head gaskets are the same thickness.          MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2020 at 7:06am
There must be a difference in cams for the D17 pistons to hit in a D19 diesel. The later D19 compression ratio is 15:1 and the D17 is 15.7:1. Machining pistons would fix it. Of course I have little experience in those engines........
Looking at the parts page it looks like the cam changed and when using the new cam you had to change to newer pistons.
I'm just babbling for my own edjamacation.Big smile
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2020 at 8:46am
Do the diesels have flat surface where valve sets requiring specific stand out? Someone put seats in my 8070 before I got it and didn't set them down...had valve marks in carbon on 4 pistons.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2020 at 11:43am
I believe they are flat
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2020 at 6:17pm
55 allis,
 I can see you have some experience in these engines and that's good. I do not. A good friend and good mechanic on these 45D engines gave me advice on them. If you want to chat P.M. me.
 Thanks for posting the picture of your tractor!
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2020 at 8:27pm
The AGCO head gaskets had a sheet of paper inside them on the piston machining needed. AGCO has killed the head gasket but Tony at Tony's tractor has one left of the AGCO gaskets left'
Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2020 at 9:21pm
Ok but already got one coming
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 7:42am
Got the one rim and tire put together and painted [IMG]http://
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 7:44am
Here is the picture, it didn’t work the first time
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:24am
Here is a better picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 2:26pm
55, that looks great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 9:05pm
Nice big 16.9's on the 45D! I like it. Wheel looks good!
Thanks for posting.
This page was generated in 0.142 seconds.
