P/U Rear Axle Fail ? |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Jun 2020 at 8:12pm |
I drove past a yard this afternoon that had multiple "cones" along the road up to a parked p/u and flatbed trailer. I just assumed that some type of landscaping work was being done until I got closer
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6495 |
Broken lug bolts from the gorilla on the impact wrench or the axle broke where it comes out of the axle housing.
They used to have a big snap ring on the inner end of the axle. At 3-400000 miles they sometimes wear out. The axle will move out like you said. I do not know it the later units had the same design.
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25237 |
If it is a full floating axle, Hubert is probably correct. If not, could be either Tom or Hubert's guess. 3/4 ton, probably full floating
I am still confident of this;
Someone forgot either the square cut key, or the snap ring that holds it in. Those AAM rears have a big retainer that threads on like a nut.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88240 |
Thanks guys. All I know is I felt bad for the poor guy, it looked like pictures of the CIH 2300 series combines with their r/h drive tire at "cab level"
copyrite1972 ![]() Orange Level ![]() ![]() Joined: 26 Feb 2016 Location: idaho Points: 331 |
His first mistake was buying a Chevy!!!
D15 Series II
I prefer ABD! anything but Dodge |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34204 |
BILs 2000 GMC K2500 is NOT a full floating rear axle, flange type like a half ton, Weight packages can be light or heavy dependent of model type and year to get a full floater. That said I see all manner of self determined home mechanic do brakes on full floating axles and never pull a hub, bad idea as to inspect the bearings is almost a necessity as badly as we abuse light trucks these days, if brakes are shot that means a great deal of heat delivered to the hubs and bearings where the grease never really fully recycles to the rear end.
