1200 Cultivator wing lock, How? |
joepro91
Joined: 25 Oct 2017 Location: Ashland Ohio Points: 16 |
Topic: 1200 Cultivator wing lock, How?Posted: 13 May 2020 at 8:34am |
Guys, how to the wings lock up for transport on my new to me 1200 field cultivator.
( it has hydraulic fold wings ). Thanks
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 13 May 2020 at 8:54am |
I used a come-a-long on mine, a chain on each wing will work.
Also removed the rod end pin of the cylinder to let the wing go all the way down and rest on the main frame, but that is a pretty good "tug" to get up again. Do not let it rest on cylinder hose fittings, they will break!
Posted: 13 May 2020 at 9:04am |
Depends on the age and width, but some of them had a special U-bolt with hairpin locks that was used as a safety lock. It was pretty crude and probably got lost or broken.
Edited by DrAllis - 13 May 2020 at 9:05am |
plummerscarin
Posted: 13 May 2020 at 9:15am |
This is on a 1350. Don't know if it's the same as yours. Have to use a come along to take the pressure off the pin to remove or lock it in.
Lonn
Posted: 13 May 2020 at 10:27am |
My 1200 goes over center but it's only 18-1/2 feet wide.
Wink I am a Russian Bot |
ac fleet
Posted: 13 May 2020 at 10:30am |
Mine had the crosspin setup on it. VERY hard to get out and in, always had to push mine over with the loader at home ---at the other farm I had to struggle with a loadbinder to get enough slack to drive the pin out.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4139 |
Posted: 14 May 2020 at 9:05am |
I'll take a picture when I get to the farm today, if I can remember.
IBWD MIke
Posted: 14 May 2020 at 2:24pm |
Here's a pic of mine. 18' 1200.
Posted: 14 May 2020 at 2:52pm |
BINGO !!!
JoeO(C-MO)
Joined: 12 Oct 2009 Location: 3rd Rock > Su Points: 132 |
Posted: 15 May 2020 at 10:20am |
Were these used on the 16 -1/2 foot also?
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts. |
Posted: 15 May 2020 at 10:31am |
If it is the same age, I'd say yes. Changes were made over the years on some items and that particular design was kinda cheesey at best.
